20 Most Recent Toshiba 1360 Black and White Copier Questions & Answers
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Toshiba 1360... | Answered on May 16, 2015
open the front door to the copier release the clam shell so you can see inside the machine gently but firm close the machine and shut the front door have a feeling the interlock switch is not in the right position
Toshiba 1360... | Answered on Jul 28, 2014
firstly change lower charger then main charger otherwise high voltage
Toshiba 1360... | Answered on Jun 25, 2013
change your toner sensor
Toshiba 1360... | Answered on Apr 12, 2013
check your IH supply
Toshiba 1360... | Answered on Mar 29, 2013
You most likely have an internal error. Bad news is that your 1360 is a little beyond obsolete and chances are parts are unavailable. You may indeed be very much out of luck. Time for a new one, sorry to bear the bad news Margaret.
Toshiba 1360... | Answered on Feb 15, 2013
first check if the cartridge is original usually "have a serial & par code"
& Shake it will & clean carefully the green ship at the end off cartridge
check if the cartridge is already opened
turn the cartridge upside down " open the wight square tab & turn the Shield the Opposite Hand
[ check if broken ] while turning it .. you must see tone Flipping or moving at the square tab window
if not that's mean shield broken
try to fill its toner to an empty cartridge..
Toshiba 1360... | Answered on Aug 27, 2012
you need spacers to properly set the doctor blade. for that model i believe the proper spacing is 0.65mm and it also sounds llike you need new developer
Toshiba 1360... | Answered on Jul 28, 2011
At the exit of the printer, there is the fuser unit (heating roller, which heats the paper to fuse the toner on to the paper. The fuser (heater) is covered with the Teflon sheet Sleeve. So that the paper is never directly in contact with the heater and heat is transferred through Teflon sleeve.
I have noticed Paper Jam at the outer paper bin in case of damaged Teflon sleeve. A very clear indication of broken Teflon is that there is a loud cracking noise, when the printer initializes (printer power on) or while printing a page. Secondly, the toner fails to fuse properly to the paper and gets erased when rubbed. You may use a torch to inspect it as well. Secondly, inspect the paper path for any obstructions. There may be a torn piece of paper. Inspect the gears and roller from the input tray to the paper exit point and look for any stuck roller.
So, it is recommended that make sure that the Teflon Sleeve is OK and there is no obstruction in the paper exit path.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Toshiba 1360... | Answered on Jun 16, 2011
clean the exit sensor or replace it
Toshiba 1360... | Answered on Jun 12, 2011
remove the glass [two screws on the scale] very carefully clean the mirror that is near the lamp that is mirror 1 then clean the two mirrors that are nearest the side that the paper comes out that is mirrors 2+3 then remove the black lens cover i think it is held in place with two screws then clean the mirror that is there dont try to cean the mirror under it yet then open your machine and remove the cleaner unit follow the wire that goes to the unit and remove the black cover and unplug the unit, remove the toner cartridge you eill see either a black screw or a gold screw remove it slide out the unit and put one side gently.then look in the machine you will se a black cover slide your fingers in on the plate nearest you and you will feel a black screw remove the screw and then the cover will be loose remove it and clean the two mirrors there as well as the discharge lamps look in the optics cavity there are two slots near the lens, slide the two pins on the cover that you removed from the inside of the machine into them and slide upwards and retighten the black screw the rest is done in reverse good luck
Toshiba 1360... | Answered on Mar 16, 2011
if you open the machine in the front is a plastic bottle make sure the bottle is empty the simble says the waste toner is full
Toshiba 1360... | Answered on Mar 08, 2011
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Toshiba 1360... | Answered on Mar 07, 2011
Toshiba 1360 Black and White Copier Logo
70 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
amir hamza
amir hamza
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
toshiba 1360 photocopier not printing
  • Office Equipment & Supplies
