20 Most Recent
Fender American Deluxe Telecaster Questions & Answers
Nashville tele that has the g string sounds off when playing
if you have the adjustable bridge try moving it back a little bit. the g string is a heavy string and will tend to go sharp when you have the string height up a little. make small adjustments usually only one turn or half a turn at a time. take care to note your adjustments so you can always go back to where you started. turners are nice but the ear doesn't lie. if it sounds right it's right
Us14014610
The guitar was made fairly recently - after 2012 probably. Like the number indicates, it's US-made. Fender does not currently offer Tele's with copper colored aluminum pickguards, so that might be an aftermarket addition, assuming, of course, the picture is actually the guitar you have.
My guitar has a to high of a pitch sound
I'm confused do you mean it is to bright in tone a different resistor will change that or do you mean its tuned to high using the tuners to bring it down with an electronic tuner will help
Single coil feeds back in
Replace with a potted/waxed pickup. Play with less gain or not so loud orstand further from or beside the amp.
I have an american delux
You are looking at the WRONG end of the guitar cable. You have a VERY unsafe guitar amplifier OR the mixer that is connected to that mic has an UNSAFE grounding condition.
If your guitar amp is an old one that has a two wire cord and a switch you change to reduce hum, take it in to have a three wire power cord installed IMMEDIATELY. Only plug into grounded receptacles. This is needed to reduce electrical noise and hum but MORE importantly is personel safety.
If the problem is with the mixer and the electrical service to the mixer, better get a professional in to analyze the problem before somebody is injured.
AS A START do this: VERIFY that ALL interconnected equipment INCLUDING your guitar amp iis powered from the same source or receptacle. This includes the venue power amps, mixer, any CD players, etc. Professionals run power back from the stage source to the mixer alongside their snake to avoid just the problem you are seeing. When they need more power at a venue, a power distribution box is used that conditions the building power and insures grounding.
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM •
Fender Music
Answered
on Dec 15, 2023
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
Number of Footswitch Buttons: 1
Manufacturer Part Number: 0994052000
It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
11/22/2022 1:29:51 PM •
Fender Music
Answered
on Nov 22, 2022
Guitar amp input not working
Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
4/17/2022 3:41:52 PM •
Fender Music
Answered
on Apr 17, 2022
