20 Most Recent
Fostex Mr16hd 16 Track Digital Recorder Questions & Answers
How can I record my songs to my tablet or my laptop
The best way is to use the USB output from the Fostex. Connect the USB cable from the Fostex to the USB input of the notebook. A Windows computer should show a USB Audio Device in the device manager. If not, you'll have to get a driver from Fostex and install that. But it should just work, it did in my Vista notebook. Then simply get any number of recording software packages (Windows 8 may have a built-in app). I've used Cool Edit and Reason 4 for recording and editing. You should not record the songs using the notebook's microphone input because (1) the analog noise of a recording generated by the notebook's A-D converter is horrible, and (2) you'll have level and impedance matching problems, even after purchasing something like a pair of Bogen WMT1A line matching transformers. Once you've got it recorded, put it in the cloud and download it onto your tablet. I don't think tablets have USB ports, but maybe yours does.
When I turn on the
Hi, the hang up is LIKELY due to the unit NOT getting a ready signal from the internal HD or CD.
If you can do a FORMAT on the HD by doing an initialize that would be the first thing to try.
These two devices may have a failure... OR the best case is if a cable connector to them has fallen off.
When I try to record an audio CD on the internal
I haven't personally used this equipment, but 9 times out 10, a hiss or noise problem is due to damaged or incorrect cables been used.
Check your cables.
Check your gear. If the inputs are TRS (1/4") the make sure your cables are to. This goes for any connection your recorder: balanced cables.
If the inputs are unbalanced, then you would use TS (1/4")
How can I get an owners manual
From
this official link you can get the owners manual (170 pages)
From
this official link you can get the supplementary manual (16 pages) for devices
without cd drive unit
From
this official link you can get the supplementary manual (28 pages) for devices
with cd drive unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
My unit is stuck in "Please Wait" mode.
The hang up is LIKELY due to the unit NOT getting a ready signal from the internal HD or CD.
MR-8. How can I hard reset?
Generally, a hard reset is initiated by pressing a dedicated reset button, or holding a combination of buttons on some mobile devices. Devices may not have a dedicated Reset button, but have the user hold the power button to cut power, which the user can then turn the computer back on.
9/8/2022 8:57:16 PM •
Fostex Music
Answered
on Sep 08, 2022
Fostex mr 16 digital multitracker, Power button has pushed bin and can not turn recorder on
First, check the fuse. You may need a magnifying glass or an ohmmeter to check it. If the fuse is bad, replace it.
If the fuse is OK,or you've replaced it, I'd suggest you take it to a pro audio service center for repair. This sounds like either a major power supply problem, or a shorted component, anywhere in the unit. It may not be cheap, but get a repair estimate so you can decide if it is worth repairing.
11/6/2018 3:50:22 AM •
Fostex Music
Answered
on Nov 06, 2018
