20 Most Recent
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Questions & Answers
Zoom G1 stuck at "d5" doesn't work...
It sounds like there may be a hardware issue with your Zoom G1 multi-effects pedal. Here are a few things you can try to troubleshoot the issue:
- Reset the device: Try resetting the device to its factory settings by holding down the "store" button while powering on the device. If the device does not respond, move on to step 2.
- Check the power source: Make sure that the device is being powered by a stable and appropriate power source. If you are using batteries, try replacing them with fresh ones. If you are using a power adapter, make sure it is the correct voltage and amperage for the device.
- Check the firmware: It's possible that there is a problem with the firmware on your device. Visit the Zoom website to see if there is an updated firmware version available for your device.
- Contact Zoom support: If none of the above steps work, it may be necessary to contact Zoom support for further assistance. They may be able to diagnose and repair any issues with your device.
Hopefully one of these steps will help resolve the issue with your Zoom G1. Good luck!
G1X not working
The first thing to check is the power source. A weak battery or adapter will cause this.
Beyond checking these the only other problems will be internal and require electronic servicing.,
Zoom g1x dc supply not working, my zoom g1x is
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
