20 Most Recent
Nintendo Wii Fit Plus for Wii Questions & Answers
On archery game using control in left hand and
you could be doing like alot of us shooters do and dropping your "bow"before you hit your target.. dont drop bow till after you hear the shot hit.. keep up to eye just like your gettin ready to shoot (but youve already shot)
Wii only in black&white
This is a common problem and it is not specific to Wii Fit Plus, it is a TV setup issue.
Access your TV's menu screen and be sure that your TV screen is expecting input from "AV" or "Video". If you have "S-Video" selected, this is the cause of why your Wii is playing black and white.
Can't get to one flag
on top of the hill, there is a flag that you have to get. if you look to the right, there is a tunnel, and then you have to go in there and then at the exit, it is a dead end sand pit. the flag is there.
How can I change my goal without creating a new
Wii fit asks this every few days at the start of the training, especially if your weight changes drastically. Try this:
Use your Mii but instead of weighting yourself, ask someone alse to do the BMI test for you. If the weight is dramatically different, Wii fit will ask you to change your goal.
Hope this helps.
Wii will not play Wii Fit Plus disc. Will play
If all other discs work fine you can take the one that is not playing back to the store. The other option is to get a your wii modified and just back the games up to a hard drive. www.wiihdmods.com just dropped their 100 game hard drives to 150.00
I have used my wii
Yes, it's completely normal. To avoid this, try to take the BMI test at the same time everyday. If you have a big meal in between the weights, it might say that.
Also, the batteries on the board may be running low. Try with some new ones and see if the problem persist.
Also, try keeping the Wii Balance board on a flat hard surface, such as the floor. Do not use it on thick carpets since it might report bad measurements.
Hope this helps.
Our Wii Fit Plus will not recognize sensor to
You need to put in the Wii fit game and bypass all the screens until it is looking for play options.Take the battery cover off of the Wii board and open the large cover on the front of the Wii console.Press the sync button inside the battery compartment on the board,then press the red sync button at the top of the open console.If the blue light stays on constant,they are synched.If not,try again.Good luck and Game On!
I have a blinking red light on my nintendo nes game system. what does that mean?
The blinking red light on your Nintendo NES game system typically indicates a connection or cartridge issue. It could mean that the cartridge isn't inserted properly or is dirty. Try removing the cartridge, blowing on it to remove dust, and reinserting it firmly. If the problem persists, you may want to clean the connectors on both the cartridge and the NES system with a soft, clean cloth or cleaning solution specifically designed for this purpose. If that doesn't resolve the issue, there might be a more serious problem with the console, and you may need to consult a technician for repairs.
