20 Most Recent
Roundup ScottsRoundUp 0394560 PT Concentrate TougWeedKiller Questions & Answers
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest
solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
5/29/2010 10:25:01 PM •
Roundup...
Answered
on May 29, 2010
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
5/25/2010 5:43:35 AM •
Roundup...
Answered
on May 25, 2010
How do I get the lid off round-off sprayer?
Almost all pump up sprayers are twist off. Push the 'D' handle (used to pump it up also) all the way in. This will have a couple of cogs that lock to the top of the unit. Then twist left (unscrew). It may take a heavy hand to get it started. If you have some silicone spray or grease, then put that on the rubber gasket before putting it back on, it will come off easier.
