20 Most Recent Echo Gas Blower 162 MPH 450 CFM Blower PB500H Questions & Answers
I have a PB-500H ECHO leaf blower that is about 4 1/2 years old. It has been running great and always starts on the first or second pull. It ran out of gas and I thought I put a mixture of has and o
The only things I know that cause low compression is poor piston rings or a worn out or scored cylinder
2/21/2014 8:34:44 PM • Echo Gas Blower... • Answered on Feb 21, 2014
Echo leafblower starts but no power
Could be Excessive carbon build up in exhaust caused problem. Remove muffler and clean exhaust side of cylinder.
10/19/2013 4:14:57 AM • Echo Gas Blower... • Answered on Oct 19, 2013
Runs like choke is stuck on
You need to make sure your oil to gas ratio is being mixed correctly - dump out the gas and dispose of the fuel IAW state laws - mix fresh oil and gas fill - fire up the unit and let it run for 10 -15 minutes to get all the bad fuel out - replace or at least clean the plug and air cleaner
1/16/2013 1:24:43 AM • Echo Gas Blower... • Answered on Jan 16, 2013
Pb500h
Hi markhammerscSounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible. Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.Note:Before you disassemble the carburetor:Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.That way you will know which way it goes back together when you reassemble it.Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.Check you fuel line condition after a while they will degrade and need replacment.Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.Be sure to mark the turns down on a piece of paper.That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.Note:The little spring inside of the carburetor goes under the float arm.That is where your fuel inlet needle/float valve is located...on the arm at the end.Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.Once you have your carburetor cleaned/rebuilt that should solve your problem.Please take time to rate me Bud
10/11/2012 9:56:23 PM • Echo Gas Blower... • Answered on Oct 11, 2012
Using the blower worked fine, now will not start
Check to see if its getting spark when the switch is on if it is then see if its getting fuel the only two things i can think of would be the switch or needs a carb kit
2/20/2011 4:26:07 AM • Echo Gas Blower... • Answered on Feb 20, 2011
Doesnot want to star i
check the plug for good fire if not change the plug then see about a carb kit
1/27/2011 3:33:36 AM • Echo Gas Blower... • Answered on Jan 27, 2011
My 16 year old son ran straight gas in blower for
Yep , Sounds like the rings have probable seized to the piston. It will probably be on the exhaust side so you may be able to take off the muffler and look inside the cylinder there to see if there are any score marks. Good luck.
1/5/2011 5:56:58 AM • Echo Gas Blower... • Answered on Jan 05, 2011
2answers
What fuel does my Echo
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
1/3/2011 12:05:18 AM • Echo Gas Blower... • Answered on Jan 03, 2011
Over heat
A few different things could be causing this problem. 1. Insufficient oil in the gas/oil mix 2. The blower housing surrounding the flywheel/fan isn't installed correctly or is clogged with dirt/debris 3. The blades on the metal flywheel that create the cooling air for the engine are damaged/broken off.
12/13/2010 10:19:28 PM • Echo Gas Blower... • Answered on Dec 13, 2010
Will only run with choke closed (cold start) at
Dirty Carb. it is not getting enough fuel. you can try a bunch of gumout. or a spray cleaner. Also check the fuel filter which is either inline or in the fuel tank.
11/28/2010 2:07:58 PM • Echo Gas Blower... • Answered on Nov 28, 2010
Pull cord or motor frozen
Unfortunately, your Echo blower gets all of its lubrication from the oil mix in the gas.
To inspect the damage, remove the muffler and look inside the cylinder with a flashlight. If you can see scrathes or scoring along the sides of the piston or cylinder walls, then there are only 2 options. Repair or replace.
The repair would involve replacing the piston and cylinder (parts are $150) If you can do the labor, that would save probably $100.
To replace, I found several on ebay and other online sites for less than $300 plus shipping.
Good luck.
11/3/2010 9:28:33 PM • Echo Gas Blower... • Answered on Nov 03, 2010
Echo SRM-210 trimmer keeps releasing all of the trimmer line. I have tried replacing the trimmer head/spool but this did not resolve the issue
Sounds like there is something either broken,stuck or missing in the head.
8/1/2023 1:18:38 PM • Echo Garden • Answered on Aug 01, 2023
2answers
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate2StrokeJim
10/31/2022 10:18:08 PM • Echo Garden • Answered on Oct 31, 2022
2answers
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50 www.youtube.com/watch?v=uFN82KDj3a8 Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
10/18/2022 9:04:26 AM • Echo Garden • Answered on Oct 18, 2022
2answers
My echo srm 225 string trimmer line will not advance. Have rewound line and clear out grass from inside head.
Sometimes the spring may need extending as over time the bumping makes the spring lose its push tension causing no line advance
10/18/2022 8:53:57 AM • Echo Garden • Answered on Oct 18, 2022
Echo Gas Blower 162 MPH 450 CFM Blower PB500H Logo
Popular Tags
24 questions posted
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
View Most Popular
Echo Garden
  • Echo Garden
Most Popular Question
doesnot want star
  • Garden
