20 Most Recent
Weedeater 2 Speed Gas Blower FL1500LE () Questions & Answers
How to check leaf blower coil
The blower has to have a kill wire / switch. If you are getting spark to the plug I would suspect another issue. Make sure you have the proper plug.
My Weed Eater FL1500LE will only run on full choke
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Need to know how to
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Cannot remove the impeller so
Assuming you have the nut/washers removed, a small amount of WD 40 on the shaft and GENTLY pry it off with whatever 2 tools you have on hand, 180 opposite each other. The only thing holding it on is a little corrosion.
I have a featherlight FL20
remove it from the tank with some needle nose pliers,, and check the filter for built up grime, also,, check the plug for fouling,, it may be getting flooded as you run it,, clean the air filter too
I have a Weedeater fl
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
