20 Most Recent
Kawasaki Krh300a Leaf Blower Hand Held Commercial () Questions & Answers
How do I check the operation of the valve on the bottom of the carburetor on a Kawasaki 23.hp lawn mower motor?
If you want to test the anti afterfire solenoid, merely disconnect the wire at the solenoid while the engine is running. It should die from lack of fuel after a few seconds, certainly less than a minute.
If the engine will not run and you suspect the afterfire solenoid, you can remove the plunger from the solenoid and put the solenoid back in bottom of carburetor and then attempt to start engine. If it still won't start/run then the problem is not the afterfire solenoid.
One caveat with this test method. If the engine kill shunt is somehow not working and engine OFF has relied on the anti afterfire solenoid, the engine won't shut off with the key. You will have to remove the NEG (frame ground) battery connection to kill the engine.
