20 Most Recent
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Questions & Answers
JD 4310 tractor hydro problem
Jeff I am having the same problem. Have you found a fix for this yet? your post is right on but for some reason we are the only two withthis problem and my local jd dealers have never seen this. , Brent
Runs good for 10 minutes then loses power
Check the crankcase oil level. If low this can cause engine to tighten up and or seize up. Check gas tank for obstructions. It could also be your col shorting out. Oh and make sure that wet grass is not plugging up the shoot. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
