20 Most Recent Polaris 3900 Sport Pool Cleaner () Questions & Answers
2answers
My Polaris 3900 Sport is
With these automatic pool cleaners, if they are not staying firmly on the bottom of the pool, it is most likely that there is air in the appliance casing.Try submerging your cleaner. Keep the cleaner vertical while you are putting it in slowly to let the air out. Ensure the unit sinks to the bottom of the pool.
8/21/2022 7:28:32 AM • Polaris 3900... • Answered on Aug 21, 2022
3answers
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM. 2. Adjust the thrust jet downward. 3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off. 4. Check for water inside the head float. 5. Empty the filter bag. You can download the 3900 Manual from the Polaris site http://www.polarispool.com/Pressure/Polaris-3900.aspx It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
8/21/2022 7:27:08 AM • Polaris 3900... • Answered on Aug 21, 2022
2answers
3900 goes round circles and stays in deep end
I had the issue of Polaris 3900 going in circles and staying on the deep end for a while before I figured out the problem. In some cases the lone wheel connected directly to the gearbox turns faster than the wheels connected to the chain causing it to veer right because of slippage. When this happens check to see if the chain is secure. It should be tight enough so that the tensioner does not touch the wheel sprocket. In my case I had to remove some 6 links from the chain and once I did this it started working well. When you disassemble the unit you will see a sticker with a diagram of the drive chain on the feedpipe. Check that the angle of the tensioner is consistent with the diagram so that it does not touch the sprocket. s-l640-undefined-undefined-5.png
8/25/2020 4:21:37 AM • Polaris 3900... • Answered on Aug 25, 2020
3answers
Hello. i have a
Im trying to fix the similar problem...the sprocket on the gearbox is worn Part# 393-204. Unfortunately. u have to buy the whole gearbox. BS in my opinion. U should just be able to buy the sprocket...Im trying to figure how to do this with Polaris.
5/18/2018 4:00:15 AM • Polaris 3900... • Answered on May 18, 2018
0answers
Polaris 3900 Sport Pool Cleaner () Logo
106 questions posted
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Sean Wright
Sean Wright
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Polaris Pool & Spa
  • Polaris Pool & Spa
Most Popular Question
3900 goes round circles stays in deep
  • Pool & Spa
