20 Most Recent
Ctm Economy Scooter 4 wheel Questions & Answers
How do I tighten a
The generic steps involved are :-
1.Locate the knob on the base of the tiller. Turn the knob counterclockwise to loosen the bolt.
2 Adjust the tiller to the desired position. Push it forward or pull it backwards until you achieve a comfortable steering position.
3 Tighten the knob on the base of the tiller. Turn the knob clockwise to tighten the tiller on the scooter.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Tire pressure for the The
This scooter may have air free tires not requiring any inflation. This type of tire has foam in the tire and is maintenance free. Look for a air inflation nozzle coming out of the tire. If you don't see one the tire is air free. If you do have a nozzle, then you can add air up to the maximum inflation pressure written on the side of the tire. Hope this helps.
CTM HS-890. THE ALARM 7 appear at ones when switch on the key. Any suggestions?
hi, that is the wigwag also known as throttle pot -- > error ..
Now what can happen is the pot is no longer in the dead centre position when you turn the scooter on or the pot is worn giving incorrect resistance to the controller .
can you see the end of the pot shaft , there should be a slot in the end of it , make sure that it is dead centre to the front of the scooter ..
Regards
Rob
The horn on my CTM HS-740 is not working. How do I check it out?
Remove the top tiller console and check connections from membrane horn switch to horn. Test for voltage to the switch with a voltmeter. Check for voltage to the horn when the switch is pressed. These horns are inexpensive and easy to replace by splicing the wires and hot gluing the new horn inside the cover.Hope this helps
