20 Most Recent
Electric Mobility Merits Pioneer 3 Hd Scooter S131 () Questions & Answers
Merits regal mobility scooter beeps 9 times
hi, normally 9 flashes means controller failure but can be caused by a bad connection.
Locate the controller and refit all connections but i recommend removing a battery terminal lead first.
Regards
2/2/2019 8:55:33 AM •
Electric...
Answered
on Feb 02, 2019
My dad has a merits 4 wheel pioneer that flashes 5 times
what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
3/9/2016 4:04:01 AM •
Electric...
Answered
on Mar 09, 2016
Where is model number?
not sure on youre model but a few scooter have all the info on the transaxel support frame .........
7/9/2015 1:33:46 PM •
Electric...
Answered
on Jul 09, 2015
I have a merits s131
Put the unit in drive mode (engage the brake) and try again. If one way doesnt work, try the other way. If this doesnt work you may have a faulty brake switch or brake wiring. Replace both and try again.
8/11/2014 7:40:03 PM •
Electric...
Answered
on Aug 11, 2014
Where is the circuit breaker
My breaker is on the deck under the seat in a clear button. as you sit on the seat it will be under you on the right.
2/2/2013 7:46:14 PM •
Electric...
Answered
on Feb 02, 2013
Battery shows charged, meter shows green but the
MKane I'm sure you checked the freewheel lever located under the right rear shroud to make sure it wasn't in freewheel. If its in drive mode are you hearing the brake click when you push in the throttle? Scooters are hard to troubleshoot because of all the different components used to make it go. It could be the throttle pot, the speed control pot, the cable going from the console to the rear of the scooter. Check the circuit breaker or fuse at the rear to make sure it hasn't popped. Check all your connectors at the rear to make sure none has come loose. Without being there this is the best I can do for you. You might contact your Provider where you got the scooter to see if they will check it for you Good Luck Hope this helps you
10/27/2010 11:37:19 PM •
Electric...
Answered
on Oct 27, 2010
Hello i have a kymco xl mobility scooter which has
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault There is a bad connection to the motor and the controllerIf 's it a Rhino controller normally a blue colour , The battery is completely empty. The scooter does not drive.• Recharge the battery immediately.If the scooter is left off for a few minutes, the battery may recover enoughto allow driving again for a short time. However, driving on an emptybattery may cause damage to the battery.Regardswww.gewizrepairs.co.uk
3/24/2022 8:52:42 AM •
Electric...
Answered
on Mar 24, 2022
