20 Most Recent
Shoprider Dasher 3 Wheel Scooter RedBlueChampagne Questions & Answers
WHEN I TURN ;MY KEY ON IT STARTS TO
Sounds like a battery problem to me. Try charging the scooter for a full 24 hours and see if the symptoms disappear. If they do, but return in a few days (or sooner), the batteries probably need replacing. Otherwise, just charge it regularly.
Battery is fully charged (as indicated by needle
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on
a regular basis (at least 8 hours once a week) or it will oxidize and solidify. If
you attach the charger, what will most likely happen is the green light
will either stay green or go to green after a very short time. When you
turn on the power chair, nothing happens, or there is enough power to turn the scooter on, but not enough to get the motors to run. The charger will indicate the
batteries are full, but instead of being full of power, they are full of
crud. Your warranty will most likely not cover replacement as this is
due to customer neglect, but your insurance
may still cover the replacement batteries if you can wait for the process to go
through. Otherwise, you will need to replace the batteries on your own,
type U1, 24v 33 amp, approx. $125 each at Batteries Plus or Interstate Battery. Good luck!
Push button to turn on and it just flashes and beeps
Hello,depending on what the series of beeps are & on whether it is a scooter or wheelchair.Then you can work out the problem.If you are trying to repair yourself,"please take a pic of anything before you touch on your mobile say,for relaying back to".Have a look at:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772,Download as a PDF File to view.Hope this was of help,have a nice day.Colin
