20 Most Recent
Pyramid PR530A Amplifier Questions & Answers
Can I replace the bulb
Hi, yes sure you can. Just be sure when disassembling to make notes where necessary to keep track of where parts go-and when you get to the lamps ( either under or in back of the meters-use a volt/ohm meter to measure to voltage so you know the size to replace them with ie.. a 6 volt or 12volt. be careful when powering on a disassembled unit ( no parts touching each other, touching a metal part of cabinet) and if you want you can wrap some electricians tape around loose or exposed parts for safety. Good luck, I hope this was of some help and thanks for choosing FixYa. Prodzilla
How to hook up a pyramid pro plus 4 channel
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
