20 Most Recent
Homedics Automatic Arm Blood Pressure Monitor () Questions & Answers
What does E1 on the screen mean? t happens when
The E1 Error symbol indicates an air circuit abnormality. Try measuring again.
If it continues contact HoMedics Customer Support 1-800-466-3342.
Hope this helped you and thanks for choosing FixYa.
3/25/2016 3:33:11 PM •
Homedics...
Answered
on Mar 25, 2016
How do i clear the readings?
Press the User Select Button to select User 1 or 2. Then press and hold the - & + buttons at the same time, while the memory recall mode and the data for the selected user will be erased automatically.
Hope that helped answer your question.
3/22/2011 9:29:11 PM •
Homedics...
Answered
on Mar 22, 2011
Lately when trying to get blood pressure "EE"
The EE symbol can mean one of three things: Excessive low blood pressure, improperly placed cuff or movement of the arm during the measurement.
Hope this helps solve the problem. If it continues, contact HoMedics Customer Service @ 800-466-3342
3/22/2011 12:19:11 PM •
Homedics...
Answered
on Mar 22, 2011
My husband got the blood
clock is for setting the clock time
M is for recall the previous measured memories
+ is for increment or go to next step
1/11/2011 1:01:40 PM •
Homedics...
Answered
on Jan 11, 2011
Readings are too high compared to doctor's
There are several reasons for 'too high' readings; the cuff is too small for your arm, the muscles of the arm are not relaxed (squeezes on the blood vessels along with the cuff), arm not elevated to about mid chest level, BP tkaen before 5 minute sit/rest.
You can take your cuff into the doctors office to have it checked by the nurse and compared to theirs, rest 5 minutes ther as well befor taking BP. Their cuff could be too big for you and so would give a false low reading.
If the calibration is off, you will have to return it to the manufacturer - check their web site or call the customer support line.
Congratulations on taking an active role in your health care!
12/2/2010 3:25:47 AM •
Homedics...
Answered
on Dec 02, 2010
I have replaced the batteries in my Homedics SC-531 body fat scale, but it will not turn on. Any suggestions?
If you have already tried replacing the batteries in your Homedics SC-531 body fat scale and are still unsuccessful, try the following:
Voltage of the battery:
Verify that the batteries are inserted correctly with respect to polarity. When you put the batteries in the compartment, make sure the marks on the inside match up with the positive and negative ends.
Battery Reliability:
Use new, high-quality batteries exclusively. It is possible for batteries to be low on charge or have a problem, even if they are brand new.
Contacts for batteries:
Be sure there is no debris or rust on the battery contacts located inside the battery compartment. Use rubbing alcohol and a cotton swab to clean the contacts if corrosion is visible.
How to Reset:
On the scale, you should see a button or other option to reset it. You can restart the system by pressing a little reset button that is located on some scales. For instructions on how to find and utilize this feature, consult the handbook that came with your particular model.
Hold on a second.
Do not attempt to power on the scale until one minute has passed after you have replaced the batteries. It may take a bit for some electronic gadgets to reset.
Make sure nothing else is wrong.
Check the scale for obvious signs of wear and tear, such as loose pieces or cracked surfaces. Get in touch with the manufacturer's customer service department if you run into any problems.
Instruction Guide:
See the instructions that come with the scale for further information. It might provide advice on how to fix common power problems or detailed directions for fixing specific problems.
Get in touch with CS:
Get in touch with Homedics's support staff if the troubleshooting instructions don't solve the issue. Depending on the problem you're experiencing, they might be able to provide you with more precise advice or suggestions.
Always refer to the user manual for specific instructions on how to disassemble the scale before handling it, and be sure to follow any manufacturer-provided safety warnings. Contacting customer service is crucial if the scale is still within the warranty period.
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
