20 Most Recent
Spa And Pool Store 03-0169-48 - Artesian Spas 6" Waterfall, Lo-Profile L.E.D Questions & Answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM •
Pool & Spa
Answered
on Mar 17, 2024
Virtual Pool 3. I need serial number for it please.
Free of charge from here. It is 23 years old, license expired.
https://virtual-pool-3.en.uptodown.com/windows
4.5/5 · My Abandonware
Description
Virtual Pool 3 is a 3D, first-person sports video game that simulates various cue sports, developed and released for Windows and PlayStation by Celeris. The game features 15 pool disciplines, snooker, and two varieties of carom billiards. Wikipedia
Platforms: Microsoft Windows,
PlayStation Portable,
Playstation
Initial release date: November 14, 2000
Mode:
Multiplayer video game
Genres:
Sports video game,
Simulation Game
Developers:
Celeris,
Digital Mayhem
Publishers:
Interplay Entertainment,
Sony Interactive Entertainment,
2K Play,
XS Games,
Gametapes LLC
Series: Virtual Pool..
1/10/2024 12:18:45 AM •
Pool & Spa
Answered
on Jan 10, 2024
OH Code how to correct so Spa runs?
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out.
So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
1/1/2024 4:40:07 AM •
Pool & Spa
Answered
on Jan 01, 2024
My lazy spa has been fine for 18 months and is now tripping electrics every time I put on to heat and filter
if your hot tub is tripping the breaker, it could be due to a worn out ground fault circuit interrupter (GFCI) breaker, which is responsible for preventing electrical surges. You can try flipping the breaker to see if it trips again. If it does, then you may need to replace the breaker.
Another possible cause of the problem could be loose electrical connections in your hot tub . This can lead to power fluctuations that cause your hot tub circuit breaker to trip. Professional electricians can inspect your hot tub and tighten any connections that are loose, which should fix the circuit breaker problem.
If your spa is not receiving power, you should check your home's circuit breaker to ensure that it's not tripped . Reset the circuit breaker if it's tripped to restore power to the spa. If the circuit breaker keeps tripping, it may be an indication of an electrical problem, and you should call a professional electrician to diagnose and fix the issue
11/12/2023 1:21:05 AM •
Pool & Spa
Answered
on Nov 12, 2023
How to change the LED colour on The Orbis by Rotospa?
On the control unit select the 'up' arrow to cycle through the LED lighting options. Some units will only have one option (Blue) while other models will have a spectrum of colours to select from. Control unit diagram illustrated here https://www.hottubhiremerseyside.co.uk/faqs/
10/11/2023 2:18:48 PM •
Pool & Spa
Answered
on Oct 11, 2023
