20 Most Recent
Briggs & Stratton Briggs and Stratton 030434 3250 Watt Portable Gasoline Generator Questions & Answers
Remove motor from generator
aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
2/9/2013 6:48:36 PM •
Briggs &...
Answered
on Feb 09, 2013
Just bought a generator 5000/6250 style but my
Try removing the spark plug and rotating the engine by hand.
It could be just a little corroded from shipment over the ocean.
But once you have it loosened up and the oil circulated, it should start much easier.
Make sure it has oil in it, because sometimes they drain the oil before shipping.
You could also have someone else try the starter rope. A new engine can be hard to start.
10/4/2010 7:24:37 AM •
Briggs &...
Answered
on Oct 04, 2010
Putting 5500 Storm Responder generator back
Maybe you can check on operation manual or ask your supplier.
If you need to have diesel generator set for power generation, please refer to a company website: www.dieselgeneratortech.com. They have doing genset for more than 43 years.
1/11/2020 7:48:39 AM •
Briggs &...
Answered
on Jan 11, 2020
Hello. I have a Generac 5000w generator with a
Doesn't look like anyone came close to answering this question correctly.While I realise I am answering a VERY old post, a correct answer may help others that come here in the future who are experiencing the same problem.The issue is with the starter clutch. It screws onto the crankshaft and works like a ratchet wrench. It allows the crankshaft to turn freely one way but "catches" if turned the oher. Most people don't maintain them properly so it gets rusty inside and the bearings don't move like they are supposed to. Hence the clutch doesn't lock.It's usually a pretty simple fix. Remove the flywheel cover, secure the flywheel so it doesn't turn then use a rubber mallet and a drift to loosen the clutch. It has normal threads so it turns counter clockwise. It should come loose pretty easily. Once off, look at the front of the clutch. There is a cover which is just pressed on. You should be able to get it loose with a hammer and small flat head screwdriver. Carefull you don't loose the bearings (there are 6) which are pretty large. Clean the whole thing out, removing any rust and debris.Then spray the inside with some lite machine oil (don't use grease or any other thick lubricant).The shaft should have a piece of felt in the center of it. This should also be soaked with machine oil. To reassemble; place the washer and shaft back into the housing, then place a bearing in each "hole". Give it another shot of machine oil and press the cap back on.Put it back on the engine and replace the cover. You should now have a workng starter. There is a small hole in the front of the clutch. You should periodicaly squirt some oil into it to keep the clutch lubricated.
1/20/2019 10:33:24 PM •
Briggs &...
Answered
on Jan 20, 2019
I have a 18 hp briggs engine. no fire with coil
hi
I think that the problem you have is not with the coil.
let me explain : when there is the need to stop the engine simply we push a button or use a lever in both cases what it simply does the coil is grounded to earth this stops the spark supply to the spark plugs . find the cable which connect from the switch on to the coil because this cable
intermits to short to earth stopping the spark going to the spark plug ( replace cable this will prevent the engine to stopping )
1/3/2018 1:39:18 AM •
Briggs &...
Answered
on Jan 03, 2018
Generator wont srart
tank filter carburetor , sprayer , gaskets (sometimes) OIL-LEVEL to low or (it can happens but not often ) defect oil-control if oil level is good temporarily pull the oil monitoring loose bougie BCPR6ET does sometimes good equivalent services.
If the ignition module is defect no sparking and you are order a new one you must know the serialnumber of the engine type to get the right one because of modifications by later build of the same models van later construction year. or there is a valve problem
But that is rare . to high overcurrent for start start the generator without connected tools .
12/2/2015 8:33:10 PM •
Briggs &...
Answered
on Dec 02, 2015
