20 Most Recent Yanmar Diesel 5500 Watt Pramac Generator Questions & Answers
Hello i need to find a capacitor for my sumec
Capacitors are normally in the end of the alternator, remove the end cover. Most generators it is there
2/19/2015 1:59:00 PM • Yanmar Diesel... • Answered on Feb 19, 2015
My generator start the breaker trips under load and stops engine but with out load no trips
First check the load and grounding, you will need to measure the amperage draw wih an ammerter, also check to see if it trips when a large unit like a motor or air conditioner starts, it may not be able to handle the inrush. Also be aware that if your breaker is a 30amp does not mean you can pull 30amp you can safely constantly draw 80% of that. Also check your grounding of the equipment you are powering.
12/9/2013 8:47:59 PM • Yanmar Diesel... • Answered on Dec 09, 2013
My engine is only one piston, when it is running
It is near impossible to restart these diesels IMMEDIATELY after stopping UNLESS you press the compression release OR let the pressure bleed off for a time.
On the top of the engine is usually a compression release lever. Press this down and crank the engine for a few seconds then release the lever and the unit should start.
On some units the lever is hard to find. My unit had a panel to remove and I have put a hinge on it to make it easy open. I now always start the unit using the compression release as it is easier on the starter motor.
5/9/2010 3:22:02 PM • Yanmar Diesel... • Answered on May 09, 2010
Can't locate my chassis number
Contact Continental Engines Greenville SC, they maybe can help you. They are Yanmar dealer
2/19/2015 1:57:17 PM • Yanmar... • Answered on Feb 19, 2015
Where do I find a manual for Yanmar Generator MD550
Contact Continental Engines Greenville SC Google them they are a Yanmar dealer
2/19/2015 1:39:59 PM • Yanmar... • Answered on Feb 19, 2015
I want to buy an avr for yanmar generator model ydg3700e
-Buy it. Good for you. Good luck Mai
12/29/2014 9:44:00 PM • Yanmar... • Answered on Dec 29, 2014
Generator running but no power output
PLEASE, PLEASE, PLEASE.... do not take this the wrong way... but there is an In-line fuse. If the Fuse is still good... STOP........... Do not work on it and take it to a repair facility. Working on this and not knowing 100% of what you are doing and without the proper training and safety equipment... YOU COULD DIE!!!!!
7/17/2014 1:14:49 PM • Yanmar... • Answered on Jul 17, 2014
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
Yanmar Diesel 5500 Watt  Pramac Generator Logo
Popular Tags
8 questions posted
Top Yanmar Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Yanmar Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Yanmar Electrical Supplies
Most Popular Question
need find capacitor sumec
  • Electrical Supplies
