20 Most Recent
Pramac Commercial 3100 Watt Honda Generator Questions & Answers
Pramac px5000 plug stuck in ac socket
If the plug of your Pramac PX5000 generator gets caught in an AC socket, follow these steps: 1. Turn off the electricity to the socket.2. Wear insulated gloves for safety.3. Gently wiggle the plug while pulling it out.4. Apply a bit of lubricant if needed.5. Use insulated pliers to grip and pull the plug.6. If you cannot take it away, get help from an expert electrician to keep it away from harm or injury.
3/19/2024 1:25:41 PM •
Pramac...
Answered
on Mar 19, 2024
How Can I Fix Pramac 12k Battery Charger Failure Alarm
If your Pramac 12k battery charger is displaying a failure alarm, there could be a few possible causes:
- Check the voltage level of the battery: Make sure that the battery is at the correct voltage level and that it is properly connected to the charger.
- Check the charger connections: Make sure that the charger is properly connected to the power source and that the connections are not loose or damaged.
- Check the charger's fuse: Make sure that the charger's fuse is not blown.
- Check the charger's cooling system: Make sure that the charger's cooling system is working properly and that it is not blocked or damaged.
- Check the charger's electronic board: Make sure that the charger's electronic board is not damaged or malfunctioning.
6/19/2023 1:41:47 PM •
Pramac...
Answered
on Jun 19, 2023
Pramac generator no power
Based on the information provided, it seems that the generator is producing voltage but not delivering it to the connected devices. Here are a few troubleshooting steps you can try:
- Check the circuit breakers: Make sure the circuit breakers on the generator are not tripped. If they are, reset them and try again.
- Check the connections: Ensure that all the connections between the generator and the devices you are trying to power are secure and not loose.
- Check the voltage regulator: The voltage regulator controls the output voltage of the generator. If it is faulty, it may not be allowing voltage to pass through to the connected devices. You may need to have it tested or replaced.
- Check the automatic voltage regulator (AVR): If your generator has an AVR, it may be malfunctioning and preventing power from reaching the connected devices.
- Check the capacitor: While a visual inspection may not always be enough to detect a faulty capacitor, it is worth checking it with a capacitor tester to make sure it is functioning properly.
- Check the wiring: Inspect the wiring for any signs of damage, such as frayed or broken wires. If you find any, you will need to repair or replace the affected wires.
If none of these steps resolve the issue, you may need to consult with a qualified technician to diagnose and fix the problem.
3/19/2023 3:12:08 PM •
Pramac...
Answered
on Mar 19, 2023
I require the valve clearance gap for a pramac p6000s diesel generator
If you need data of valve clearance gap of the diesel generator, you can check on the operation and maintenance manual. If still can not find, try to ask your supplier whom supplies the diesel generator to you.
If you need to have a generator set in future, please refer to www.dieselgeneratortech.com.
1/6/2020 2:57:39 AM •
Pramac...
Answered
on Jan 06, 2020
Pramac px 5000 generator gets hot cuts out?
The air duct is blocked by dust and the ventilation is poor, which makes the heat dissipation of the generator difficult. The dust and oil dirt in the air duct shall be removed to make the air duct unobstructed.
12/21/2019 1:46:11 AM •
Pramac...
Answered
on Dec 21, 2019
