20 Most Recent Mi T M MiTM 6000 Watt 13hp Honda generator Questions & Answers
I sounds like it might be the low oil shut off. it has a bypass that allows it to start but then cuts off after a few seconds. even if the oil is fine the sensor may be bad.
Mi T M MiTM 6000... | Answered on Nov 03, 2011
unless you are a master electrician this becomes very complicated. First you need a generator that is large enough to power everything in your house, then you need a auto power up system
Guide to Buying Standby Generator
Mi T M... | Answered on Aug 04, 2015
With water running, drop a few ice cubes down the disposal.
Electrical... | Answered 20 hours ago
Anything plugged into it? A Surge protector can cause this.
Does the generator require you connect the gender to ground from a lug on the side? It may be expecting this.
It really depends on what load is connected.
If theres no load connected (gen only) call customer service.
Electrical... | Answered on Jul 13, 2019
Request the diagram directly from the manufacturer/distributor.
Electrical... | Answered on Jul 12, 2019
I need a wiring diagram for a Steele SP-GG350 generator.
These outlets give trouble sometimes. Check if there is voltage in the outlets if not check the main switch.
Mi T M MiTM 6000 Watt 13hp Honda generator Logo
Popular Tags
6 questions posted
Top Mi T M Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a Mi T M Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mi T M Electrical Supplies
Most Popular Question
honda em5000s generator issue will
  • Electrical Supplies
