20 Most Recent Buffalo Tools GEN120C 1000 Watt Portable Generator Questions & Answers
The motor on my generator has lost spark. I
Post make, model and serial number from frame of unit and I can help. I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
10/5/2013 2:26:58 PM • Buffalo Tools... • Answered on Oct 05, 2013
My Buffalo 2000 watt gen, about 1 to 2 years old,
The electrical coil, that is the spark plug cable with the coil,change it.
10/3/2013 1:43:59 AM • Buffalo Tools... • Answered on Oct 03, 2013
0answers
How do i fix the recoil starter, does it have a
CALL me ***************** i will tell you how it goes THANKS
8/9/2011 3:48:00 PM • Buffalo Tools... • Answered on Aug 09, 2011
2answers
I need a wiring diagram for a buffalo tools 7,000 kw propane generator - any idea where to get one?
try googling buffalo tools 7,000 w propane generator manual 7000 kw is a very large unit - 7,000,000 watts
2/5/2022 9:31:15 PM • Buffalo Tools... • Answered on Feb 05, 2022
BUFFALO TOOLS 2000 WATT GENERATOR 12 VOLT OUTPUT BUT NO AMPS WILL NOT EVEN LIGHT A 12 VOLT TEST LIGHT BUT VOLT METER READS 12 V.D.C. WHAT IS WRONG ? PLEASE HELP.LABEL SAYS FOR 12 VOLT BATTERY CHARGING
have the voltage regulator system checked in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
5/8/2016 1:06:32 AM • Buffalo Tools... • Answered on May 08, 2016
2answers
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:- water cooled engines inlet hot .010"--exhaust hot .012" for air cooled engines inlet hot .012"-- exhaust hot .014"
9/25/2015 10:45:04 AM • Buffalo Tools... • Answered on Sep 25, 2015
Do you have a manual for a buffalo tools 2000 watt portable generator?
HOPE THIS LINK WORKS. http://www.buffalotools.com/manuals/gen154manual.pdf it is the Gen you got, I have same.. Condenser failed after 7 yrs. Just suddenly stopped putting out. Kept running nicely though!
5/18/2014 1:25:11 PM • Buffalo Tools... • Answered on May 18, 2014
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
Buffalo Tools GEN120C 1000 Watt Portable Generator Logo
7 questions posted
Top Buffalo Tools Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Tools Electrical Supplies
Most Popular Question
buffalo 2000 watt gen about 1 2 years
  • Electrical Supplies
