20 Most Recent
Kwikset 4 Lido Lh Passage Levers Satin Chrome 200ll 26d Questions & Answers
Could you send instructions for
Sure, let me give you a link to the installation instructions for the Kwikset Lido(keyed lock):
http://s7d5.scene7.com/is/content/BDHHI/44593-01
If this is not what you had in mind, go to this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Levers_Lido
and select the model most like yours. Clicking on the picture will bring up installation and warranty links, etc.
Please note that if I haven't been able to help you, then I urge you to contact Kwikset Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
How to install single cylinder handleset with lido lever
I'm not sure whether you need instructions for an entry door or an internal bedroom or closet door. So let me steer you to the online site: Go to :http://www.kwikset.com/Products/Categories/Door-Levers.aspxThen "Browse by function" for the appropriate type, then choose the LidoOn the next page, you can click on any Lido finish, the instructions will be the same regardless of finish.Once you 're on the next page, under the red "Technical Documents" heading, choose "Installation Guide".It will take a moment to download the PDF file of the installation instructions for you to follow.A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/Good luck!
Kwikset 4 Lido Doesn't lock
Yow will need to do some investigative disassembly and reassembly to spot the problem.Here is a link to the installation instructions for your lock (in five languages!) to assist your operation:http://s7d5.scene7.com/is/content/BDHHI/44593-01A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/And here is the link to Kwikset's lifetime warranty against mechanical defects, wherein you will find the contact number to call them for further customer assistance and parts replacement:http://s7d5.scene7.com/is/content/BDHHI/warranty2009Or, if you wish, call them before you disassemble your lockset.Good luck--and please provide feedback if this helps!
The key hole is completely
Advanced product search: http://www.kwikset.com/Products/Advanced-Product-Search.aspxcustomer service http://www.kwikset.com/Customer-Support/Contact-Us.aspxGood luck!
My soon lock the bathroom
The short answer is that you can't get the doorknob off from the outside.
Lock sets and door knobs are purposely made that way to thwart any potential thief with a screwdriver from simply removing the door knob to gain access into our homes and rooms.
What you MAY TRY is to carefully pry loose the door trim in the area of the door knob away from the door jamb. You may have to carefully remove a trim nail in the process.
Then experiment with a flat, thin, solid tool like one of those rounded spatulas used for frosting cakes slipped in between the trim piece and the jamb. Your goal is to try to get the spring latch to retract away from the door's strike plate like James Bond with a credit card. Look at one of your other open doors to visualize how the mechanism works.
This is going to require some patience, but it may save you from having to destroy the door or frame to get into the room.
Kwikset 730LL-RH handle fall out,
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
We have the thumb press elongated handle on the
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
I have a Schlage F51
when you say "removing all hardware" do you mean,All hardware such as hinge pins and or hinges to get the door off?
Trying to replace a door
can you pull the hinge pins so you can remove the door. if so that will make it easier to work on
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
