20 Most Recent
Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Questions & Answers
Weiser lock diagram
The installation instructions:http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdfA note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/
How do I turn the
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
How to remove the back
The Weiser brand and Kwikset brand Powerbolt are identical (Black
& Decker), so these instructions will work just fine for you:http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspxNotice
that the above is a .PDF file type. That means that you need to have
Adobe Reader or similar installed on your computer to view it. So if you
are unable to view the file, download (for free) and install Adobe
Reader first. You can get it here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
I need to reset the code
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The
steps below are to change your access code to a new code. This will
also remove any previous codes stored in the Powerbolt's memory.
- Manually
put the bolt in the extended (lock) position. Press the PROGRAM button
once, enter your new 4 - 8 digit code and then press the LOCK button.
- Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
- Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If
your old code still remains in the unit, you will need to perform a
hard reset of the unit. To perform a hard reset of the unit, remove all
four batteries and leave them out for 1 hour. After the hour has
passed, you may re-enter the batteries.
When i unlock my door , it locks & unlocks
Try this:
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
When lock button is pushed,
Sounds like the lock was instaled wrong. If the lock has been there for some time then the lock has gon bad and needs to be replaced.
Good Luck
On my house door lock, I recharged my batterie and now the lock wont work
When it comes to rechargeable batteries there is an unspoken rule to not use them for smoke detectors, clocks, and menial electronics. Only use them for flashlights and stereo systems that you carry on your shoulder. :) All you can do is make sure that the batteries are touching all the terminals and that they are facing the right way.
