20 Most Recent
Weiser Lock GED1460X GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol Questions & Answers
How do i change the code?
The Weiser brand and Kwikset brand Powerbolt are identical (Black
& Decker), so these instructions will work just fine for you:http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspxNotice
that the above is a .PDF file type. That means that you need to have
Adobe Reader or similar installed on your computer to view it. So if you
are unable to view the file, download (for free) and install Adobe
Reader first. You can get it here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
How do i delete old access code and enter new
Here's the link that you need:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I'd recommend changing the batteries at the same time that you are reprogramming the lock if it's bee a while.
Keeps beeping after installing new
Here's the link to the troubleshooting procedure for the Powerbolt, wherein beeping is discussed:
If this doesn't help, I recommend contacting their Customer Support for further advice and parts:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Partial draw back of bolt on the 1st attempt with
I understand that you've already checked for any mechanical binding within the lock and between the lock and the strike plate--(does this problem occur when the lock is cycled when the door is open?)
I'm including a link to the troubleshooting page for your powerbolt:
If you don't find a solution here, although the lock is beyond its one year warranty, I'd still contact Weiser Customer Service (preferably by phone) and appeal to them to help you troubleshoot or replace your lock. Here's the contact information:
I just purchased a home with one of these types of
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
We,ve never been able to get it to work and my
Let me assume that you've already installed the Powerbolt 1000 (the one that matches the picture!), so let me link you to the Troubleshooting instructions, which illustrates how to open and reprogram the lock:
Please install fresh batteries at this time.
Also please take a look at this link,
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
which tells you how to locate and change the jumper to set the lock up for a door which is "right-handed" or "left handed"-in other words, what side the door hinges are on as you face it from the exterior. If the jumper is set wrong, the lock will not function properly.
Lastly, here's a link to the Weiser cutomer Support contact page:
Changing the unlock code.
On my house door lock, I recharged my batterie and now the lock wont work
When it comes to rechargeable batteries there is an unspoken rule to not use them for smoke detectors, clocks, and menial electronics. Only use them for flashlights and stereo systems that you carry on your shoulder. :) All you can do is make sure that the batteries are touching all the terminals and that they are facing the right way.
