20 Most Recent
Heath Zenith Wireless AddOn Wall Switch in Almond (BL6133LA) Questions & Answers
I have a Heath Zenith
By pulling it apart and following the circuit path it should be fairly apparent how to 'bridge out' the faulty PIR sensor.
If it is not, or you are not sure, then (no offence), you really shouldn't be playing with it. Some units are transistor bypass and some are relay. Cheers
When door bell is pushed
The unit is receiving electricity so low-voltage transformer and button are working correctly.
Only suspect left is door chime itself.
Check that voltage of transformer matches voltage of chime.
Use cheap multimeter from home center and check voltage at chime, or check transformer.
Doorbell transformers are usually located in basement or garage or attic, and most are hardwired into octagon box.
There are no replacement parts for door chimes.
Buy new one, or contact seller for refund if this is new chime.
Can a neighbor motion light
Hello rob.... yes, your neighbor's light may well interfere with yours in that IF the neighbor's light is coming on first, your light will sense that it is daytime and it will not come on. These lights have sensitivity adjustments on them, generally, and the eye can often be redirected. A little experimentation may be necessary. Joe
Thanks for choosing Fixya!
Connecting a Heath Zenith Doorbell 172C-A
Do you have a transformer with it? Apparently this doorbell can operate on AC or DC (3-6VDC or 8-16VAC). The usual method is to supply 110 VAC to a transformer with an output of about 16VAC. ------ BE SURE YOU KNOW WHAT YOU ARE DOING WHEN DEALING WITH 110VAC. HAVE A CAPABLE ADULT HELP YOU WITH THIS! -------
Connect one of the two outputs from the transformer to one of the terminals on the bell (this might be labeled COMMON) The other output from the transformer will go to your handheld lead (like in the Operation game). Connect a lead from your patient (as in the Operations game) to a terminal on the bell which is probably labeled for AC.
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
Can i use this tester to check for any live wires. im installed a new light fixture on my porch from existing wiring but lights not tuning on
However, I can provide guidance on using a basic voltage tester to check for live wires when troubleshooting a light fixture installation.
Using a Voltage Tester:
Non-Contact Voltage Tester:
If you have a non-contact voltage tester, it's a handy tool for quickly identifying live wires without direct contact. Hold the tester close to the wire insulation or the terminal screws, and it should indicate the presence of voltage without making physical contact.
If you have a contact voltage tester, make sure it's designed for the voltage level you're working with (e.g., 120V for residential electrical systems).
Turn off the strength to the circuit on the circuit breaker or fuse box.
Safety First:
Always prioritize safety. Make sure the power is turned off before working on any electrical components.
Test the Tester:
Test the voltage tester on a known live circuit to ensure it's functioning properly.
Check the Wiring:
Once confirmed, turn off the power to the circuit you are working on.
Use the voltage tester to check each wire connected to the light fixture. Verify that there is voltage on the wires.
Neutral and Hot Wires:
Typically, a light fixture will have a hot wire (usually black) and a neutral wire (usually white). Make positive each wires are linked properly.
Ground Wire:
Check for a ground wire and ensure it's properly connected. Some light fixtures may have a green or bare copper wire for grounding.
Switch Position:
Ensure that the wall switch controlling the light fixture is in the ON position.
Bulb Check:
Confirm that the light bulbs in the fixture are working and properly installed.
Circuit Breaker Check:
Double-check the circuit breaker or fuse for the lighting circuit to make sure it hasn't tripped or blown.
