20 Most Recent Woods 17321 Outdoor Power Strip Timer with 3Outlets and 6Foot Cord Questions & Answers
0answers
Need instruction manual for outlet
Open following links for possible DT300 manual:
I don't see load rating in manual, but 1000Watt would be typical for timer with 2-prong outlet.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
If manual is not correct:
Other folks have asked for DT300 manual, but didn't like provided manual.
Timers can have many different numbers, and different timers can go by same number:
1) Add a comment with link to in-focus photo of timer posted on Flickr, for possible identification.
2) Open following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
8/8/2011 12:30:49 AM • Woods 17321... • Answered on Aug 08, 2011
I have a outdoor Woods
Thanks for using Fixya.
Please remember to vote for any solution that helps you out.
Dennis
7/1/2011 6:14:28 PM • Woods 17321... • Answered on Jul 01, 2011
I have the woods 6 outlet timer and lost the
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Woods-17321.pdf
1/23/2011 7:14:33 PM • Woods 17321... • Answered on Jan 23, 2011
Woods 50016 Outdoor Digital Block Heater Timer. It will not program.
Question edited for a lot more clarity. All question need 'make model what is is)' as first words in the question. Question moved from Lands Phone to Woods Timer. Phone number removed. This site has 11 million views a year, how many would you like to phone you? Instructions and videos. Follow carefully. If that doesn't work, contact Woods for warranty replacement. https://www.google.com/search?q=woods+50016+timer+instructions ..
1/1/2024 4:35:09 AM • Woods Hardware &... • Answered on Jan 01, 2024
How to program a 1000 watt Woods outdoor timer that has only one button.?
If you look on the back, you will find the instructions engraved in it. You will need good eyesight. Is it the one with the photocell for Christmas lights? Plug it in, press the button once for set, press again until you reach the number of hours (say 6) after dark you want it it on. Take note that when you set it, the light will be on. It won't work properly until the next day. On at dusk (5:00pm is) and off after the preset (6) hours. https://www.google.com/search?q=woods+outdoor+timer+instructions Two button
12/10/2023 7:32:12 PM • Woods Hardware &... • Answered on Dec 10, 2023
Woods 59008 timer would not toggle and stay in 10-20-30-60 minute position
Hari, DISCONNECT POWER..circut breaker.. FOR 30-60 SECONDS AND REAPPLY, SOMETIMES A POWER SURGE CAN LOCK UP THE ELECTRONICS AND THIS WILL RESET IT. Otherwise Amazon has them for $13.00. Best to you.
7/9/2023 5:17:04 PM • Woods Hardware &... • Answered on Jul 09, 2023
Just installed a Woods model 59101R timer. The clock stops turning at 10pm every night.
It is faulty. Take it back for exchange. On old / aged models is is a sticking motor or missing teeth in a sprocket. https://www.google.com/search?q=woods+model+59101r+timer+clock+stops+working ..
5/26/2023 5:39:31 PM • Woods Hardware &... • Answered on May 26, 2023
Why won't my woods timer set right
It is possible that your Woods timer is malfunctioning due to a power surge or power outage. You can check the time settings by pressing the "SET" button on the timer and then using the "+" and "-" buttons to set the time. If the timer is still not setting correctly, then it is likely the timer is damaged and needs to be replaced.
1/4/2023 1:19:31 PM • Woods Hardware &... • Answered on Jan 04, 2023
2answers
Does my woods timer model50015 have to be in Auto mode for my programmed times to run.
yes it does. the manual allows you to turn device on and off when you want.
11/20/2022 10:52:55 PM • Woods Hardware &... • Answered on Nov 20, 2022
2answers
Need instruction for the Woods #50013
I can’t get all the letters on the timer. I only get F? Is there a trick to it??
4/2/2022 11:22:12 AM • Woods Hardware &... • Answered on Apr 02, 2022
I have a Woods #50008 indoor light timer. It's out of syn and I need to re-program it. How do I do that?
hi find link for user manual of 50008 timer https://usermanual.wiki/Document/Woods50008Instructionmanual.118656238
11/23/2021 4:20:19 PM • Woods Hardware &... • Answered on Nov 23, 2021
Would this Woods digital timer model 50029 work in an unheated garage. Can go down to -25 F
Question edited for clarity to add maker (what it is). Moved categories from Refrigerators to Woods Timer. Yes, no problem. The display creates a small amount of heat. https://www.google.com/search?q=digital+model+50029 ..
8/23/2021 9:51:09 PM • Woods Hardware &... • Answered on Aug 23, 2021
Setting timer of Woods 50012 timer
Mans.io has a manual that may be similar
8/13/2021 8:26:52 AM • Woods Hardware &... • Answered on Aug 13, 2021
I have a 111 woods light timer and wondering how to use it. could you please show me or tell me
Mans.io has a manual this one may be similar
8/13/2021 8:25:41 AM • Woods Hardware &... • Answered on Aug 13, 2021
How to print a manual for the 50015 manual for woods timer?
I don't see it available for print but you can see it here.https://mans.io/files/viewer/751219/1#navigate_bar
8/13/2021 8:11:25 AM • Woods Hardware &... • Answered on Aug 13, 2021
How to program #49556 te158wta
Woods 49556 / TD1300 manual
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
4/6/2021 11:15:22 AM • Woods Hardware &... • Answered on Apr 06, 2021
Woods 17321 Outdoor Power Strip Timer with 3Outlets and 6Foot Cord Logo
6 questions posted
Top Woods Hardware & Accessories Experts
vince
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
outdoor woods
  • Hardware & Accessories
