20 Most Recent Woods 7 Day Digital Heavy Duty Timer (59377) Questions & Answers
I hope I am stating
I have 59377 timer in my office.
Here is copy of manual:
http://waterheatertimer.org/pdf/Woods-59377.pdf
What job do want the timer to do?
It sounds like you want a programmable timer at night, and simple on-off switch at day.
Add a comment if answer below misses the mark.
YES, the manual override can be used as on-off switch.
Press manual override until Manual ON or Manual OFF display.
The manual override button has 4 states:
Auto ON, turns lamp ON immediately and programming resumes at next set time.
Auto OFF, turns lamp OFF immediately and programming resumes at next set time.
Manual ON to choose permanent ON.
Manual OFF to choose permanently OFF.
8/26/2011 2:45:04 AM • Woods 7 Day... • Answered on Aug 26, 2011
Hello, I have model 49556/te158wt and I'm not able
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
10/13/2010 8:39:10 AM • Woods 7 Day... • Answered on Oct 13, 2010
Woods 50016 Outdoor Digital Block Heater Timer. It will not program.
Question edited for a lot more clarity. All question need 'make model what is is)' as first words in the question. Question moved from Lands Phone to Woods Timer. Phone number removed. This site has 11 million views a year, how many would you like to phone you? Instructions and videos. Follow carefully. If that doesn't work, contact Woods for warranty replacement. https://www.google.com/search?q=woods+50016+timer+instructions ..
1/1/2024 4:35:09 AM • Woods Hardware &... • Answered on Jan 01, 2024
How to program a 1000 watt Woods outdoor timer that has only one button.?
If you look on the back, you will find the instructions engraved in it. You will need good eyesight. Is it the one with the photocell for Christmas lights? Plug it in, press the button once for set, press again until you reach the number of hours (say 6) after dark you want it it on. Take note that when you set it, the light will be on. It won't work properly until the next day. On at dusk (5:00pm is) and off after the preset (6) hours. https://www.google.com/search?q=woods+outdoor+timer+instructions Two button
12/10/2023 7:32:12 PM • Woods Hardware &... • Answered on Dec 10, 2023
Woods 59008 timer would not toggle and stay in 10-20-30-60 minute position
Hari, DISCONNECT POWER..circut breaker.. FOR 30-60 SECONDS AND REAPPLY, SOMETIMES A POWER SURGE CAN LOCK UP THE ELECTRONICS AND THIS WILL RESET IT. Otherwise Amazon has them for $13.00. Best to you.
7/9/2023 5:17:04 PM • Woods Hardware &... • Answered on Jul 09, 2023
Just installed a Woods model 59101R timer. The clock stops turning at 10pm every night.
It is faulty. Take it back for exchange. On old / aged models is is a sticking motor or missing teeth in a sprocket. https://www.google.com/search?q=woods+model+59101r+timer+clock+stops+working ..
5/26/2023 5:39:31 PM • Woods Hardware &... • Answered on May 26, 2023
Why won't my woods timer set right
It is possible that your Woods timer is malfunctioning due to a power surge or power outage. You can check the time settings by pressing the "SET" button on the timer and then using the "+" and "-" buttons to set the time. If the timer is still not setting correctly, then it is likely the timer is damaged and needs to be replaced.
1/4/2023 1:19:31 PM • Woods Hardware &... • Answered on Jan 04, 2023
2answers
Does my woods timer model50015 have to be in Auto mode for my programmed times to run.
yes it does. the manual allows you to turn device on and off when you want.
11/20/2022 10:52:55 PM • Woods Hardware &... • Answered on Nov 20, 2022
2answers
Need instruction for the Woods #50013
I can’t get all the letters on the timer. I only get F? Is there a trick to it??
4/2/2022 11:22:12 AM • Woods Hardware &... • Answered on Apr 02, 2022
I have a Woods #50008 indoor light timer. It's out of syn and I need to re-program it. How do I do that?
hi find link for user manual of 50008 timer https://usermanual.wiki/Document/Woods50008Instructionmanual.118656238
11/23/2021 4:20:19 PM • Woods Hardware &... • Answered on Nov 23, 2021
Would this Woods digital timer model 50029 work in an unheated garage. Can go down to -25 F
Question edited for clarity to add maker (what it is). Moved categories from Refrigerators to Woods Timer. Yes, no problem. The display creates a small amount of heat. https://www.google.com/search?q=digital+model+50029 ..
8/23/2021 9:51:09 PM • Woods Hardware &... • Answered on Aug 23, 2021
Setting timer of Woods 50012 timer
Mans.io has a manual that may be similar
8/13/2021 8:26:52 AM • Woods Hardware &... • Answered on Aug 13, 2021
I have a 111 woods light timer and wondering how to use it. could you please show me or tell me
Mans.io has a manual this one may be similar
8/13/2021 8:25:41 AM • Woods Hardware &... • Answered on Aug 13, 2021
How to print a manual for the 50015 manual for woods timer?
I don't see it available for print but you can see it here.https://mans.io/files/viewer/751219/1#navigate_bar
8/13/2021 8:11:25 AM • Woods Hardware &... • Answered on Aug 13, 2021
How to program #49556 te158wta
Woods 49556 / TD1300 manual
http://waterheatertimer.org/Woods-timers-and-manuals.html
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
4/6/2021 11:15:22 AM • Woods Hardware &... • Answered on Apr 06, 2021
How to set a woods timer? It has two buttons hour and program. On front has IIIWOODS
Woods timers and manuals appear on following link: http://waterheatertimer.org/Woods-timers-and-manuals.html More information appears on following link: http://waterheatertimer.org/How-to-set-timers.html
11/10/2019 12:02:35 AM • Woods Hardware &... • Answered on Nov 10, 2019
Woods 7 Day Digital Heavy Duty Timer (59377) Logo
3 questions posted
Top Woods Hardware & Accessories Experts
vince
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
model 49556 te158wt not able
  • Hardware & Accessories
