20 Most Recent Woods 2C 24 Hour Indoor Mechanical Timer (59200) Questions & Answers
They're ALL Down when you get the timer.. It would be helpful for them to state that in the instruction. Instead they tell you to push the pins down to set. Bur they're already all down!
Woods 2C 24 Hour... | Answered on Jun 03, 2019
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
If you have the digital timer, generally you can toggle DST back-and-forth 1 hour by pushing two buttons simultaneously for 3 seconds. And then reverse the setting again by pressing and holding both buttons again.
Open link. Download manual. Look for 'daylight savings time' in manual. Read instructions.
You can unplug timer to make programming changes, since the timer has a carryover feature against power outage.
To restore functionality of a timer that no longer works, press reset button and then reprogram.
The Woods 50000 series are new line of timer introduced just before Christmas 2012.
Woods timers are warranted by Coleman/ Carol Cable/ Canadian tire, and I suspect the timer itself is made by Intermatic.
All these timers have standard 1 year limited warranty against workmanship defects.
I have not seen any complaints about this line of timers here at fixya.
Add comment if you need more help.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Woods 2C 24 Hour... | Answered on Apr 18, 2013
Timer is not identified.
Check following options.
1) Add a comment and describe timer in detail
2) Open following link for typical Utilitec digital plug-in timer, with links to other Utilitec timers.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
3) Open following link for setting Utilitec analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Woods 2C 24 Hour... | Answered on Sep 22, 2011
Open following link for setting analog timers by experimenting with features:
Woods 2C 24 Hour... | Answered on Sep 13, 2011
Timer not identified for certain:
Open following links to see how to set analog timers by experimenting with features, and identify different timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59202
Add a comment any time for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Woods 2C 24 Hour... | Answered on Sep 11, 2011
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
Woods 2C 24 Hour... | Answered on Sep 02, 2011
Woods 59200 has segments located around edge of timer dial, and Woods 59201 has pins.
Some manuals say pins, when they mean segments, and some manuals call segments pins.
Pins:
http://waterheatertimer.org/images/GE-mechanical-pins-1-200.jpg
Segments:
http://waterheatertimer.org/images/GE15107-004-2-166.jpg
The following link tries to sort out the pin-segment issue with illustrations:
Take a moment and vote on answer:
Woods 2C 24 Hour... | Answered on Aug 28, 2011
I don't have repair for defective timer.
1) Open following link to help identify timer, and then add a comment with timer number and description how you set timer, and what you have tried so far:
2) Open following link to see how to set analog timers, and read troubleshoot steps, and then add a comment with as much information as possible:
3) Add a comment and describe timer in detail and what you have done so far so timer expert is not guessing.
Woods 2C 24 Hour... | Answered on Aug 25, 2011
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Woods 2C 24 Hour... | Answered on Aug 15, 2011
Each pin/segment represents 30 minutes.
To set timer for 2 hours, move 4 consecutive pins/segments up or down.
For 8 hours, move 16 consecutive pins/segments
http://waterheatertimer.org/images/Raise-segments-240.jpg
Dark background for numbers are usually 'night' or 6pm to 6am.
Timers usually have am and pm printed on timer dial.
Open following link for analog timer instructions:
Woods 2C 24 Hour... | Answered on Jul 19, 2011
Woods 59202 is 7-day analog VACATION timer and cannot be set.
Vacation timers are preset to turn on-and-off at random times so it looks like somebody is home when you are away.
You might want the 59201 analog timer which can be set for on-off times over 24-hour period. Minimum on-off is 15 minutes.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
If you need a 7-day timer, buy a programmable instead of analog. Wooods 59377 or Intermatic DT630 heavy duty
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU
If you have analog plug-in timer, open following link to see how to set timers:
Woods 2C 24 Hour... | Answered on Jul 05, 2011
Woods 2C 24 Hour Indoor Mechanical Timer (59200) Logo
36 questions posted
Top Woods Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
cannot set timers off
  • Hardware & Accessories
