20 Most Recent
Cooper Wiring Devices ACE 3WAY ROTARY PUSH DIMMER Onoff push Questions & Answers
Two red wires, 1 black wire and a green wire. In
make sure your application is correct first,this switch is controlled from at least 2 locations,you cant put 2 dimmers on the same light,if you have taken the wires directly off the switch you will wire the white to the black of the dimmer and the 2 reds to each of the other wires,the white in this case is you pivot or constant hot,the other wires are the travelers
