20 Most Recent
Pyramid PWFX107 Car Subwoofer Questions & Answers
Bottoming out
Well, If you're sure they're not blown, they're either bottoming out because you're overpowering them, or your box is not the best. I'd recommend putting them in a sealed box. even run some caulk inside where every peice of wood meets another, just to make sure it's sealed. If your box isn't sealed well at the edges, or your ports are too big, the speaker will have excessive excursion (in & out movement), causing bottoming out, and voice coil damage. Plus, I just like the nice tight bass from a sealed enclosure. Hope this helps.
750x to 2 10" pyramids
There sould be an input level control on the main amp that drives these woofers. Adjust the input so that even iof the stereo is tuned up all the way the amp is limiting the amout af input. Before you do this and turn up the stereo, turn down the amp input control all the way then you can slowly bring it up when you turn up the stereo's volume. Good Luck
Pwfx107
its hard to tell whats wrong with so little info , but theres alot that you can check ,
Is your amp putting out the power ? If the amp is a Pro series 750x amp then check your amp inputs they might be too low hence low output. Otherwise i would like to know what size of enclosure you have these spekers on and how they are connected to the amp.
What is a pyramid schemes?
Hi Linda, It's called a pyramid because it starts with one person putting money into a fund, Say it's a guy, He then invite as many people as he can(say 10) to do the same and then those 10 people invite as many as they can(say 10 each x10=100) and so on100x10=1,000) and on(1,000x10=10,000)... see how it grows... And what happens is the 1st guy gets a percentage of the money from the 10 people he invites plus a percentage from the 100 people they invited and it goes on and on, , the people he invited get a percentage of the people they invite plus a percentage from the people they invited and so on and on and it just keeps going and going and the higher on the list you are the more money you get but the lower on the list you are the more you struggle as it gets harder and harder to make money because everybody above you on the list are all getting a percentage from people all down the list until eventually everybody on the bottom of the list looses all their money and that's why it's *******......DO NOT DO IT, If you make any money from this scheme just know it's from people loosing theirs, Take care.........
