20 Most Recent
Briggs & Stratton Briggs Stratton 2550 Psigaspressure Washer Questions & Answers
Engine working fine, but water not coming out
Couple of things, is the water supply good? if that's a yes, then check to see if there is a way to engage / disengage the pump, some models offer that, if engaged and good water supply, then it has to be your pump
5/2/2018 5:48:38 AM •
Briggs &...
Answered
on May 02, 2018
Won't start
I could be the timing is off.
You can check it with a feeler gauge.
Place a 0.08- to 0.012-inch feeler gauge tool between the flywheel magnet and ignition armature legs to adjust the ignition armature air-gap for proper ignition timing. I’m happy to help further over the phone at
https://www.6ya.com/expert/karl_14766549451f8563
7/19/2017 6:56:26 PM •
Briggs &...
Answered
on Jul 19, 2017
The firwt time this year
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
7/6/2011 12:54:43 AM •
Briggs &...
Answered
on Jul 06, 2011
Pressure washer stop during operation
first check that there is fuel in tank.
then check that the fuel tap is turned on.
check the spark plug,if it has a build up on it then replace.
1/10/2011 10:10:43 AM •
Briggs &...
Answered
on Jan 10, 2011
Briggs & stratton 17.5 hp has fuel, spark and good air filter no start.
Likely either the engine is flooded or low compression.
A simple go no go compression test is remove spark plug and press a thumb or finger firmly over the plug hole and crank engine. It should forcibly push your finger and make a loud PFFfft sound. No or little sound equals insufficient compression.
If the push rod was not bent, there was no reason to replace. If it was bent then I question how you set proper valve lash with new pushrod as the typical cause for a bent rod is a displaced valve guide.
If compression is OK then likely it's simply flooding and you have a carb float/inlet needle issue. Crank engine, remove plug and if it's saturated with fuel then it's flooded and a flooded engine will not fire, even with starter fluid.
Comment for further assistance.
11/6/2023 1:03:20 AM •
Briggs &...
Answered
on Nov 06, 2023
Briggs & Stratton 450 series 148cc. How to get higher revs?
Remove and sharpen the blade. If the blade is sharp, it will slice though the grass with no resistance. Over time, the cutting edge gets blunted by stones, grass and soil. If that doesn't fix it, remove the carburetor, strip and clean all the jets. Make sure you count the turns and write down any pilot jet settings.
5/13/2023 3:30:01 AM •
Briggs &...
Answered
on May 13, 2023
