20 Most Recent
Hitachi CS33EB16 16" Rear Handle Chain Saw Questions & Answers
I was wondering if there
The oil pipe is poorly fitted to the oil pump and allows bar/chain oil to sneak past the seal. Buying a new oil pipe may not fix the issue since this is common on brand-new saws. Warranty work probably won't help you.
How I fixed my saw: I bought two small O-rings about the diameter of the oil pump and fitted them to act as hose clamps around the oil pipe. See attached picture. It worked perfectly and now my saw runs out of fuel before oil. Sears/Craftsman have a great video on how to remove the clutch assembly.
Hitachi Blower not priming
hi
just because you brought it 4 years ago does not mean it is four years old thats when you first used it the machine itself could be 6-7 years old
anyhoo
it sounds to me that when you stored your tool up last time may be for the winter
there was still fuel left in the carburetor
what happens is any fuel left in the carb will expand in cold weather and when it expands it stretches the diaphragm inside the carburetor
hence as soon as you touch the throttle it will probably flood the engine making it hard to start
i will need the full information on the make model engine size
