20 Most Recent Tally Serial Matrix T2030 Printer Questions & Answers
I need the drivers for my tally 2030/9 printer for
hi
go to folowing link you will have your drivers for windows7
http://www.latestdriversupdate.com/driver/66082.html
5/21/2010 8:39:38 AM • Tally Serial... • Answered on May 21, 2010
Printer is bleeping for delivery note to be
I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
  1. Put the printer Offline
  2. Press Setup
  3. Press the button under PaperWay
  4. Change this to Tractor 1
  5. Press SET
If the above steps do not work disconnect the printer from the computer then try again.
For more info see the Dascom web site;
http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
And look for the Online Single & Load section
11/20/2009 12:15:30 AM • Tally Serial... • Answered on Nov 20, 2009
Tally T2030 matrix printer prints 2 copies of
On the device config for the printer on the AS\400 it is possibly configured to print 2 copies.
wrkcfgsts *dev printername
check and see if it is configured to print 2
6/18/2009 5:46:12 PM • Tally Serial... • Answered on Jun 18, 2009
Exiting Tally; File not found;lang.900; Please reinstall Tally and make sure that lang.900 exists in the application folder.
it may be due to incomplete installation as well as may be some files are deleted or removed
2/10/2020 10:32:06 AM • Tally Office... • Answered on Feb 10, 2020
We are getting code lost sync 28 what does that mean? We have the Tally 6312 connected to the AS400
check line in is not broken look at the socket
1/17/2019 10:15:46 PM • Tally Office... • Answered on Jan 17, 2019
Unable to create company path c\tally.erp 9\Data\10005
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
8/4/2018 7:17:51 AM • Tally Office... • Answered on Aug 04, 2018
How do I get my Tally printer to print faster?
answer in your last post
11/17/2017 6:42:27 PM • Tally Office... • Answered on Nov 17, 2017
Tally Serial Matrix T2030 Printer Logo
5 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
tally t2030 matrix printer prints 2
  • Office Equipment & Supplies
