20 Most Recent Tally Serial Matrix T2130 Printer Questions & Answers
I cant find drivers for windows 7 on the tally
You can download it directly from here: http://www.latestdriversupdate.com/driver/36545.html
Hope this helps. If so, please rate. Thanks.
4/19/2010 8:20:55 AM • Tally Serial... • Answered on Apr 19, 2010
Printer screen message reads turn paper lever
I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
  1. Put the printer Offline
  2. Press Setup
  3. Press the button under PaperWay
  4. Change this to Tractor 1
  5. Press SET
If the above steps do not work disconnect the printer from the computer then try again.
For more info see the Dascom web site;
http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
And look for the Online Single & Load section
11/20/2009 12:15:04 AM • Tally Serial... • Answered on Nov 20, 2009
Printer reinitializes during printing
Hi Update the printer driver. Good Luck.
2/15/2008 7:25:16 AM • Tally Serial... • Answered on Feb 15, 2008
Exiting Tally; File not found;lang.900; Please reinstall Tally and make sure that lang.900 exists in the application folder.
it may be due to incomplete installation as well as may be some files are deleted or removed
2/10/2020 10:32:06 AM • Tally Office... • Answered on Feb 10, 2020
We are getting code lost sync 28 what does that mean? We have the Tally 6312 connected to the AS400
check line in is not broken look at the socket
1/17/2019 10:15:46 PM • Tally Office... • Answered on Jan 17, 2019
Unable to create company path c\tally.erp 9\Data\10005
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
8/4/2018 7:17:51 AM • Tally Office... • Answered on Aug 04, 2018
Tally Serial Matrix T2130 Printer Logo
3 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
printer screen message reads r nturn
  • Office Equipment & Supplies
