obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Contact Senco service with a view to having it professionally repaired.
Repair Service Centers and also 'Ask a Senco Professional'.
https://www.senco.com/parts-and-service
PDF
FinishPro® 18Mg. 18 Ga. Brad Nailer. NFD81UMG Revised Mar. 11, 2014 (Replaces ... Fire." B First, ? pull trigger, then. ? push safety element against work surface for operation each time ... ? Double Action et ? Restriction. Dans certaines ...
A Restrictive Trigger tool will reduce the possibility of double fire and may reduce the speed of operation compared to a Dual Action Trigger tool. Call Customer ...
Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" ... I would double check the plunger to make sure its resetting after each fire. Helpful 0 ...
Oct. 25, 2003 - I have a brand new bostich framing nailer and it is constantly double nailing and getting jammed. ... consider the senco framer I recently saw packaged with an 18 gage stapler for only $199 at Lowes. ... You can make the best of nailers double fire. ... Podcast 331: PRO TALK With Cabinetmaker Ben Scott ...
NO. NO. NO! That canister is full of an explosive mix of propane (butane) and is designed for a single use. Besides the potential of serious injury or worse, you'll also void your tool's warranty.
Almost every compressor has a pressure control unit, but it could also be that the rubber or plastic buffer which receives the piston has a problem that the tip of the firing pin thereby comes a little too deep
