20 Most Recent
Heavy Duty Arrow T50 Staple Gun Questions & Answers
Pull out the spring loaded mechanism out
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution. Thank you for using FixYa.
I don't understand how to
we have one, you push in at the back and pull down take out the rod put the staples in and put rod back in and push up it locks itself, hope it helps
How do I open a model T-50 staple gun?
On the rear of the stapler (if you look at the picture on this web page, the lower right) there is a metal piece that you push in, then down slightly, to unlock. When you release it, a spring loaded bar and follower will come out. You will see where the staples slide in. Put the follower back in the grooves and reinstall.
How do I adjust the depth the brads are counter sunk
There is a dial located by the business end of the Brad that adjusts the depth it fires. Also make sure you air pressure ( written on the stapler ) is set to level issued by the manufacturer. It'll say something like max pressure 90 psi. That would mean you will need to adjust the regulator pressure on your compressor to no more then 90 psi or to what ever number that is written on that sticker. Use a test piece of wood and turn the pressure down if you have no luck until you get the desired results.
