20 Most Recent
Hitachi CP-X443 Multimedia Projector Questions & Answers
Dead hitachi 443
This unit uses a DC to DC converter, and it is very sensitive to voltage spikes, it does have a fuse on the power supply and it also has 4 solid states fuses that look like transistors and resistors on the power supply board.Tony Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/tony_a41fa0b801734e2f
My hitachi cpx 443 lcd
How defined are the dots? Is each blue dot limited to the size of a pixel? I suggest you create a 3 slide image in powerpoint ..one slide completely blue, 1 red and one green. then project each image in turn and note what happens with the blue dot. My first thoughts are you have some pixels that are locked. Once that happens if are pretty much stuck with them. Optical it is impossible for a dust on the lens etc to cause them as if the picture is in focus at the screen the dust is way out of the depth of the field, sometimes you can focus the projector so that the point of focus is the lens surface but then the actual content will be way out of focus...none of which has anything to do with your blue dots. Regards Kevin Andreassend, ICE AV Technology Ltd, http://www.digitaldaytime.com
Need to clean filter dont
look under the projector lens and you will see a cover that can be hinged out when the plastic claw lever is pressed in. lift the filter out by the knob
I own a Hitachi cpx443
I think this is the problem with polarizer.With the LCD block removed you can hold the assembly up at an angle to a light and inspect each polarizer for damage. Polarizer which is a glass sandwich assembly right in front of and attached to the green LCD panel frame.There is a plastic membrane laminated to the glass on both sides of one panel or slide which is the actual polarising element.If thereis any damage in the polarizer replace it with the help of authorised technician.
Thanks
Smith.
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
- Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
- Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
- Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly
As a first step, remove the filter (s) and clean them well or replace them with new filters.
It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt
I hope you can make your Hitachi work properly
Regards Franco Dosil
Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente
Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos
Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad
espero Puedas hacer funcionar correctamente tu Hitachi
Saludos Franco Dosil
Hi, my Hitachi CP-X445 projector will not stay running for more than 5 minutes when mounted feet up, but there is no problem running feet down, any ideas?shuts down on high temp
Thanks, Jose
the lamp is not good
you need a Original lamp
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
Hope to cooperate with you.
Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps
www.Lampdeng.com
I have a yellow spot on my Hitachi cpx10000 projector.
the Lcd panels are fault
or
the polarizer isfault
www.Lampdeng.com
What could have happened to the projector to get a large blob that changes shape and is purple colored. Like an amoeba that grows and moves around.
Font strokes are not cleaned
Black silk font is not black enough
reason:
WhatsApp ID:+8613178867858
Skype:
[email protected]
Wechat ID:+8613178867858
Email:
[email protected]
Email:
[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
My hitachi A120n projector has no power light checked internal fuse and ok .
The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Hitachi projector cp-wx3041wn problem Power & temp light on ? How to solve
You should clear the air filter
and reset the air filter timer and the lamp timer
menu-advance-option-reset the air filter
menu-advance-option-reset the lamp filter
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Posted on May 31, 2019
