20 Most Recent Tally T8006 Laser Printer Questions & Answers
0answers
Error HW F5
Be the first to answer 1/28/2014 7:31:28 AM • Tally T8006... • Posted on Jan 28, 2014Be the first to answer
I want the drivers
Go to their website and download the drivers from there using your make and model number
6/18/2010 12:01:56 PM • Tally T8006... • Answered on Jun 18, 2010
Printer error TALLY T8006 SVC F4 ERROR
I belive the SVC F4 error indicates the fuser fan is not functioning.
Check the fan is connected correctly, also check if the fan is working.
If the fan is not working it may need ot be replaced, alternativly it may be a IOD1 Board or the MCTL board
12/14/2009 11:47:31 AM • Tally T8006... • Answered on Dec 14, 2009
Tally t8006 colour laser constantly gives paper
Please unplug the printer cable eject the paper and uninstall the printer driver comletly and restart the computer after that reinstall the printer driver and insert the paper in paper tray.
it should be work now
8/30/2009 5:18:34 AM • Tally T8006... • Answered on Aug 30, 2009
2answers
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
6/23/2008 12:12:42 AM • Tally T8006... • Answered on Jun 23, 2008
Tally T8006 Network set up
Power the printer on whilst holding down the TRAY button to access the Network Menu
3/31/2008 7:27:02 PM • Tally T8006... • Answered on Mar 31, 2008
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Rosener
2/9/2008 11:34:20 AM • Tally T8006... • Answered on Feb 09, 2008
T8006
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
6/25/2007 11:49:31 AM • Tally T8006... • Answered on Jun 25, 2007
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
6/19/2007 4:42:17 PM • Tally T8006... • Answered on Jun 19, 2007
Can't Print with Tally T8006 Laser
can u print anything else?, if donĀ“t disconnect the printer, reinstall drivers and connect again.
1/17/2007 8:00:44 PM • Tally T8006... • Answered on Jan 17, 2007
Exiting Tally; File not found;lang.900; Please reinstall Tally and make sure that lang.900 exists in the application folder.
it may be due to incomplete installation as well as may be some files are deleted or removed
2/10/2020 10:32:06 AM • Tally Office... • Answered on Feb 10, 2020
We are getting code lost sync 28 what does that mean? We have the Tally 6312 connected to the AS400
check line in is not broken look at the socket
1/17/2019 10:15:46 PM • Tally Office... • Answered on Jan 17, 2019
Tally T8006 Laser Printer Logo
20 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
printer error tally t8006 svc f4 error
  • Office Equipment & Supplies
