20 Most Recent Stihl Ts 510 760 Cut Off Saw Repair Manual Questions & Answers
Gas oil mix
50 parts fuel to 1 part oil.
4/6/2019 11:59:29 AM • Stihl Ts 510 760... • Answered on Apr 06, 2019
0answers
My weed eater sounds
if it's an older unit start with pulling the muffler and cleaning exhaust port and spark arrestor. while muffler is off sta.rt the unit and check for improvement. if no improvement clean & adjust carb. if improved with no muffler, test again with muffler installed. if unit goes back to running poor replace muffler.
7/25/2011 5:08:18 PM • Stihl Ts 510 760... • Answered on Jul 25, 2011
I can't find a Stihl
Hello. STIHL Canada doesn't list either the 510 or the 760, it seems to be a STIHL USA item (??)Here is the link for the manual. It is about 1/3 of the way down the page listed under the heading " Construction Tools ", on the right hand side.
Let me know if this helped out.
http://www.stihlusa.com/information/info_product2.html
6/12/2011 12:21:49 PM • Stihl Ts 510 760... • Answered on Jun 12, 2011
TS 510 av saw. My
There could be a few problems. Check the air filters and make sure that no holes are present in them. Then check to make sure the unit has compression. A general check of the compression for a Stihl unit is to hold the unit up by the rope and it should hold itself up. If it slips down really quick or if it does not hold itself for more than a couple of seconds before the rope starts coming out, then the unit is low on compression and will need a new piston and cylinder.
Also another thing to check is the carburetor. With the new fuel with ethanol/methanol in it, it can damage parts in the carburetor. The sealant that went over the welch plugs will come off and it will flood the unit out because there is no regulation of the fuel going into the engine. You can try putting new sealant, such as clear fingernail polish over them, and see if it holds and will regulate the fuel correctly. If the air filters have holes in them then the low compression could be caused from dirt ingestion and it could have caused wear on the main bearings. You can check for bearing wear by seeing if the flywheel or the clutch will move up and down and sided to side. If this is the case then you will need to purchase a new unit.
5/10/2011 12:57:34 AM • Stihl Ts 510 760... • Answered on May 10, 2011
STIHL TS760 cut off saw repair manual needed
Hello. Found the link for downloads, they also have contact info should your model not be online. http://www.stihlusa.com/information/info_product2.html
Hope this helped.
3/21/2011 12:01:26 PM • Stihl Ts 510 760... • Answered on Mar 21, 2011
I need to replace the
This is not difficult. The impulse hose as it is called presses on to a brass fitting under the intake manifold. remover the filter housing, filter, carburetor, and tank as needed to make room to get in and replace it. Parts can be ordered from you local dealer like www.arcolawn.com
Hope it helps
Joe
please vote me up if it did help.
2/20/2011 10:39:58 PM • Stihl Ts 510 760... • Answered on Feb 20, 2011
Stihl Ts 510 760  Cut Off Saw Repair Manual Logo
27 questions posted
Top Stihl Saws Experts
john h
ADMIN Eric
ADMIN Eric
Are you a Stihl Saw Expert? Answer questions, earn points and help others
View Most Popular
Stihl Saws
  • Stihl Saws
Most Popular Question
gas oil mix
  • Saws
