20 Most Recent Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Questions & Answers
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
9/6/2022 8:08:49 PM • Stihl Ts400 Cut... • Answered on Sep 06, 2022
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
9/7/2019 9:59:25 PM • Stihl Ts400 Cut... • Answered on Sep 07, 2019
How do i set up
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
2/2/2019 10:20:11 PM • Stihl Ts400 Cut... • Answered on Feb 02, 2019
2answers
Fuel is running through carb flooding out when pulling to start
The float valve is stuck open. It's time to rebuild the carburetor.
7/7/2018 2:01:52 PM • Stihl Ts400 Cut... • Answered on Jul 07, 2018
Saw has compession fuel and spark but will not start
You might check the air filter to make sure it's clean. Also make sure the kill switch is in the on position.
9/2/2015 11:31:13 PM • Stihl Ts400 Cut... • Answered on Sep 02, 2015
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
1/1/2015 5:56:00 PM • Stihl Ts400 Cut... • Answered on Jan 01, 2015
Ts400 doesn't start up, used to start but when it
Sounds like it is Over heating to fast take to the shop and see if they can find you a part or you can try changing the fuel in it and set it in full throttle for about 5 seconds and do this for a minute.
1/1/2015 5:54:12 PM • Stihl Ts400 Cut... • Answered on Jan 01, 2015
The cord wont pull out like it is jammed but when taken off the saw its fine
poss pawl damage or rewind spring
11/29/2014 5:10:33 PM • Stihl Ts400 Cut... • Answered on Nov 29, 2014
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
5/19/2014 4:48:14 PM • Stihl Ts400 Cut... • Answered on May 19, 2014
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced a
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head. Sorry for the bad news (if I am right).
4/23/2014 6:32:05 PM • Stihl Ts400 Cut... • Answered on Apr 23, 2014
Stihl quick cut no start
the metering lever is stuck having been stored prior to installation
12/15/2013 7:32:32 PM • Stihl Ts400 Cut... • Answered on Dec 15, 2013
0answers
0answers
Sthil
Be the first to answer 7/12/2013 5:00:01 AM • Stihl Ts400 Cut... • Posted on Jul 12, 2013Be the first to answer
Wot is the fuel mix for a partner k 750 disc cutter
50-1 with Husqvarna two stroke oil, but 25-1 with other two stroke oil as the quaility is unknown, always try to use Husqvarna two stroke oil
3/10/2013 10:35:16 PM • Stihl Ts400 Cut... • Answered on Mar 10, 2013
Petrol stihl
Stihl machines have a plastic pawl in the rope pulley, a small r clip retains the pulley and creates some friction on the pawl, as the pulley turns the clip tries to stay still due to the tention this in turn drags the pawl out and into the flywheel drom, so you either do not have enough tention on the r clip, or the small plastic dog has broken.
2/10/2013 4:36:55 PM • Stihl Ts400 Cut... • Answered on Feb 10, 2013
0answers
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
41 questions posted
Top Stihl Saws Experts
john h
ADMIN Eric
ADMIN Eric
Are you a Stihl Saw Expert? Answer questions, earn points and help others
View Most Popular
Stihl Saws
  • Stihl Saws
Most Popular Question
rebuilt stihl ts400 concrete saw now
  • Saws
