The nut on the larger spring in the pump pressure switch:
Usually the larger nut in the pump pressure control switch adjusts the
pump cut-on ("cut-in") AND pump cut-off pressures simultaneously. This
is the left-hand spring (and nut) in our photo.
That means that whatever the gap is between the cut-on pressure and
the cut-off pressure, that gap is maintained, but the entire operating
range of the pump is raised or lowered. Turning the large nut
clockwise RAISES BOTH the cut-on and cut-off pressures. So turning
the large nut clockwise shifts the whole operating pressure range of the pump UP to HIGHER pressures.
Conversely, turning the large nut counter-clockwise will lower the
whole pump operating range. This is the simplest adjustment to make.
Photo (left) courtesy of a
reader.
The nut atop the smaller spring in the pump pressure switch: this nut is used to narrow or widen the gap between the pump cut-on and pump cut-off
pressures. This is the right-hand spring (and nut) in our photo).
Turning the small nut
clockwise (tighter) will
RAISE the CUT-OFF pressure,
and vice versa, loosening or turning the nut
counter-clockwise will lower the cut-off pressure. Watch out! If you
loosen this nut too much you can set the cut-off pressure below
the cut-on pressure and the pump will turn on and run forever (or until
it burns up.)
Which nut to turn in the pump pressure switch control, and which
direction to turn it, are usually visible on a label inside the pressure
switch cover.
Above we show photos of a common
Square D water pump pressure control switch (Schneider Electric) and the label with pump control adjustment details. [Click to enlarge].
Here are Example Pump Pressure Switch Adjustment Instructions from Square -D
Understanding how pump pressure control switches work and which way
to turn which of the two nuts in the control can be confusing.
On a Square-D Pumptrol® 9013FSF-2 pump pressure switch, for example, Square D tells us that we
- Turn the Range Nut #1 (the larger
spring and nut) clockwise (to the right or "down") to raise [both]
cut-on and cut-off pressures. This is "tightening the nut down" against
the spring. ("Rightie-tightie, leftie-loosie" as Mara Gieseke says to
her kids). Thanks to reader Rise for this clarification.
In other words, adjusting the pressure on this spring shifts the whole
operating range of the switch up or down, but keeps the difference
between cut-in and cut-out the same, whatever it happens to be
(typically it's about 20 psi from the factory.)
If you want the pump to turn ON (cut-in) sooner, that is, at a higher water pressure, turn the nut clockwise or "tighter".
If you want the water pump to turn ON (cut-in) later, that is, at a
lower water pressure, turn the nut counterclockwise or "looser".
- Turn the Differential Nut #2 (the smaller spring and nut) clockwise to raise the cut-out pressure.
If you want the water pump to turn OFF (cut out or cut-off) at a higher water pressure, turn this nut clockwise or "tighter".
If you want the water pump to turn OFF (cut out or cut-off) at a lower
water pressure, turn this nut counter clockwise or "looser"
Here is why the small nut is called the "Differential"
Keep reading at
LINK
