20 Most Recent
Samsung UN40F6300AFXZA - UN40F6300AF 40 1080p LED-LCD TV - Questions & Answers
Got a Samsung smart TV un40f6300afxza has a dark picture everything else works fine what can it be?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
12/7/2016 7:42:26 AM •
Samsung...
Answered
on Dec 07, 2016
No picture or sound, red light blinks 5 times, already replace tcon and power board still blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
11/23/2016 5:11:44 PM •
Samsung...
Answered
on Nov 23, 2016
Samsung un40f6300af has stopped working. it will power on but the screen does not light up
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
9/8/2016 5:52:14 AM •
Samsung...
Answered
on Sep 08, 2016
Samsung TV UN40F6300AF lower half of screen wont light up. 7 rows of LED bottom 4 wont light up.
http://electro-medical.blogspot.com/
4/8/2016 7:28:46 AM •
Samsung...
Answered
on Apr 08, 2016
Why won't it turn on?
11/18/2015 12:34:25 PM •
Samsung...
Answered
on Nov 18, 2015
Samsung le26a6 will not switch on
If blinks continue without any pause, the main board is faulty.
