20 Most Recent
Hitachi UX21511 Projector Lamp for 50V500 Questions & Answers
the ballast is broken, you need a new one
USD60 for a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Installed new lamp. lamp light blinking
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
Hitachi 50V500 lamp light turned on so we called
The real issue here is you have one of two things wrong:
1.) The set has a bad ballast or other problem that destroyed the lamp.
2.) Someone replaced the lamp with a "Generic bulb" which means they used either just a bulb or a cartridge with a bulb in it that was not FROM HITACHI.
If you decide to go on the web and buy another---GET A ORIGINAL FROM HITACHI---LAMP THIS WAY SHOULD COME WITH AT LEAST A 6 MONTH WARRANTY.
LOTS OF PEOPLE RUN into trouble with "generic" parts in sets like this; they just to not perform as well or last as long. If the lamp that was in the set to begin with lasted over 2,000 hours I think a generic or poor replacement was used.
If I can help you let me know by a COMMENT HERE. If you found my suggestions helpful rate this solution with a "very helpful" rating as I do this here for free.
REGARDS, SD TECH
I have a samsung that the screen was pink now, black with sound??
What you describe is a classic symptom of burned out fluorescent tubes in the display. I'm assuming this tv is a LCD model...Unseen by the user, there are long, thin, extremely bright, fluorescent tubes along the edges(usually top and bottom) which light up a backscreen so you have a vivid image to look at. (sort of like how a doctor views xray pictures) As the tubes age, they change color and eventually burn out. An excellent example of the same technology is a laptop display or desktop lcd display--same exact design. Hopefully your unit is under warranty because this is an involved repair *if* it can be done. Most often, the whole lcd display unit must be replaced. Definitely shop around for repair facilities if non-warranty is a factor.
Hitachi 50V500
Sounds like the lamp has gone or the filter needs cleaning.
UX21511
Hi Timmy1369
Compare the actual size and wattage of the two with each other , if it is exactly the same then why not.
There is a lot of brands and models on the market that use the same lamps.
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
- Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
- Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
- Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly
As a first step, remove the filter (s) and clean them well or replace them with new filters.
It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt
I hope you can make your Hitachi work properly
Regards Franco Dosil
Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente
Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos
Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad
espero Puedas hacer funcionar correctamente tu Hitachi
Saludos Franco Dosil
Hi, my Hitachi CP-X445 projector will not stay running for more than 5 minutes when mounted feet up, but there is no problem running feet down, any ideas?shuts down on high temp
Thanks, Jose
the lamp is not good
you need a Original lamp
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
Hope to cooperate with you.
Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps
www.Lampdeng.com
