20 Most Recent Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F Questions & Answers
Need info on 16 hp tecumseh on a 1987 argo
Try Sears Parts Direct.com they will give you the info.
9/5/2018 1:20:39 PM • Tecumseh Enduro... • Answered on Sep 05, 2018
I need the valve spec for a tecumseh enduro 16hp
Try Parts tree Repair Clinic
6/2/2018 1:45:05 AM • Tecumseh Enduro... • Answered on Jun 02, 2018
Valve settings ohv
Check with Parts Tree Repair Clinic
5/2/2018 3:05:11 PM • Tecumseh Enduro... • Answered on May 02, 2018
Owners manual/ caberator diagram
parts tree.com will help if not try SearsPartsDirect.com
4/4/2018 12:05:01 AM • Tecumseh Enduro... • Answered on Apr 04, 2018
Carb adjustment Enduro 16 OHV
try PartsTree.com they can help
4/4/2018 12:03:19 AM • Tecumseh Enduro... • Answered on Apr 04, 2018
Wiring digram 16 hp tecumseh
check with PartsTreeRepairClinic they may help
3/8/2018 3:56:03 PM • Tecumseh Enduro... • Answered on Mar 08, 2018
What are the valve settings on13.5 tecumseh engine
Tecumseh.com will give you that
3/3/2018 11:53:05 PM • Tecumseh Enduro... • Answered on Mar 03, 2018
How and where can i find recoil pat ***. for tec.enduro eng.mod#ohv16?
Amazon or Ebay or Car Parts.com they also have mower parts
12/25/2017 7:42:55 PM • Tecumseh Enduro... • Answered on Dec 25, 2017
2answers
No Spark OH 160
has to be iginition coil take coil offf and look for a part noumber get on amazon or ebay type in model and part noumber you should find it hope this helped.
12/9/2017 10:59:21 PM • Tecumseh Enduro... • Answered on Dec 09, 2017
Why tecumseh 8 hp backfire when running
adjust the valves would be my first guess.
9/23/2017 1:37:41 PM • Tecumseh Enduro... • Answered on Sep 23, 2017
Mower starts and runs for 10 - 15 seconds, then
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
10/9/2013 2:12:40 PM • Tecumseh Enduro... • Answered on Oct 09, 2013
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc. I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
10/9/2013 2:09:28 PM • Tecumseh Enduro... • Answered on Oct 09, 2013
Have no spark to spark plug 16ohv 201142b
It sounds like you probably have a bad ignition coil. It's located under the flywheel cover and is usually attached with two screws. The spark plug cable originates from it. You can gap the new one with a business card placed between it and the flywheel.
10/9/2013 2:04:37 PM • Tecumseh Enduro... • Answered on Oct 09, 2013
Sparkplug settings/16 ohv tecumseh
Use a Champion N4C gapped at .030
10/9/2013 1:55:56 PM • Tecumseh Enduro... • Answered on Oct 09, 2013
Spark plug specs
The plug you need for a Tecumseh Enduro OHV16 is a Champion N4C, and it should be gapped at .030 . Hope that helps.
10/9/2013 1:54:25 PM • Tecumseh Enduro... • Answered on Oct 09, 2013
10 hp tecumseh throwing oil out the breather tube
There is excessive blow- by from the combustion process which indicates worn rings /broken rings or scored bore (engine worn out or dusted). Check oil level in sump as excessive oil will also cause the problem
10/7/2013 4:38:09 AM • Tecumseh Enduro... • Answered on Oct 07, 2013
Ihave no compression
Check and replace the rings, might need to be bored out. If your handy then you could hone it and go up to the next size ring. If not take to your local repair shop and they will accommodate you. Good Luck...
10/26/2012 2:07:41 AM • Tecumseh Enduro... • Answered on Oct 26, 2012
What are the settings on the valves on the ohv 16
Hi and welcome to FixYa, I am Kelly
From page 88 of the service manual under specifications both the intake and exhaust valve clearances are 0.004.
Service manual is here:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
Thanks for choosing FixYa,
Kelly
9/15/2011 1:34:58 AM • Tecumseh Enduro... • Answered on Sep 15, 2011
I have a 10 hp
If you locate the model number of your motor you should be able to download an Operator's Manual for the motor form this site:
http://www.tecumsehpower.com/
Is this an actual Tecumseh brand snow blower or another brand with a Tecumseh motor installed?
1/28/2011 4:20:15 AM • Tecumseh Enduro... • Answered on Jan 28, 2011
I need to know how to wire a new ignition switch
http://www.ereplacementparts.com/ then type in your model number found on back or under seat ei 40560x50c and you will get parts and diags drawing. Good luck Henry
1/5/2011 8:26:53 AM • Tecumseh Enduro... • Answered on Jan 05, 2011
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
Popular Tags
29 questions posted
Top Tecumseh Garden Experts
john h
Ngoro
superjulimaximo
superjulimaximo
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
View Most Popular
Tecumseh Garden
  • Tecumseh Garden
Most Popular Question
sparkplug settings 16 ohv tecumseh
  • Garden
