20 Most Recent
JVC DLA-HX1 Multimedia Projector Questions & Answers
Lamp replaced, sequence from Manual (p.49) for 2010+ hrs fails
Apparently, the above posted steps do work, but they are finicky. The manual suggests that you do the aforementioned steps with the remote - I had tried with the remote and when that did not work I tried directly on the controls on the unit itself. Neither had worked - after multiple attempts, hence the posting above. The solution was that the various steps need to be done speedily - when I previously did it I apparently did not press the sequence rapidly enough. Nothing in the manual suggests that this is the case (and in fact I thought I had previously followed the steps in rapid succession on at least one of the many times I had tried, but apparently not quickly enough). I never could get this rapid succession of steps to work with the remote (as the manual said I needed to), but I did ultimately get the rapid succession of steps to work when done directly to the unit itself. The first three steps need to be completed within approximately 1-1.5 seconds, the final push of the volume+ button did require 2 or more seconds before the process was recognized (and complete). Never did have a single FixYa party try to address my issue - perhaps you only really get responses from them when you pay for their monthly service.
JVC Camcorder GR-AX2 error code E04?
The error code E04 on a JVC Camcorder GR-AX2 indicates a problem with the cassette mechanism. This could be caused by a number of issues, such as a jammed cassette, a malfunctioning cassette compartment, or a problem with the camcorder's loading mechanism. In order to fix the issue, the camcorder may need to be serviced by a professional. In the meantime, you can try removing the cassette and reinserting it to see if that resolves the problem.
good luck
How do I repair Jvc 42 inch screen black still has sound.
Check the voltage on TCON board and mainboard. For more helpfull articles about tv repair check the jestine's yong blog (www.jestineyong.com) you can search on his blog, sure you can find more clues to help you.
Cheers !
