20 Most Recent
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Questions & Answers
John deere 325
could be a couple of things... fuse? switches? bad clutch?
John deere troubleshooting
I have model 917-276900 tractor starts fine but when I engage the mower deck it blows the fuse and dies.
John deere stx46 won't move in forward or reverse
There is a handle on the rear of mower make sure it is not in the free wheel position. If so push it in and it should move. If not seek out an authorized dealer to test your tranny. Also check that your belt didn\'t break
Why won't the starter motor engage?
Disconnect both ends of the wire and clean them with sandpaper. Also clean the battery (+ and -) starter and relay terminals. You may need to replace the relay.
Why mower blades will not engage when buttom is pulled
I believe this one has an electric clutch. Check to see that the switch is operating properly, that the wiring is good to the clutch, and that the clutch is good. Use a volt meter to check that there is voltage to the clutch when the switch is operated.
Mower blades will not engage on my STX38
Turn the key switch to the on position. Pull the blade engagement switch on.Look under the engine and find the electric clutch. Disconnect the wire connection there and while using an ohm meter, check and see if there is 12 volts on one of the wires. If so, then the clutch may be your problem. If not, then you need to trace back the wire from the clutch connection and find out why there is no voltage
