20 Most Recent
Cub Cadet Lawn Mower Blade Drive Belt CUB CADET 75404077 CUB CADET 95404077 Questions & Answers
Have a Cub Cadet 1320
check that the idler pulley is assembled on the belt properly as the belt is not to run against itself at any time
I need abelt routing diagram
This is a Parts diagram website. Find your model then work through it until you find what you need
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Pto wont engage when mower is hot
Hiyour PTO is built just like a wound up coil and becomes magnatized it gets real hot and it shorts out when it heats up make sure you have no frayed wires which will creat a large risistance and really heat upJoe
My john deere 14sb mower starts but kills when I
Check your safety seat switch. Unplug the wiring harness to the switch and place a paper clip into the harness. This will bypass the switch unless you have a continuity tester to test the switch.
