20 Most Recent
Olympus DS-330 Digital Voice Recorder Questions & Answers
Olympus handheld says "please wait"
Swapped out the USB cable with a different one and the display showed, "REMOTE". Hope this helps someone out. I've been troubleshooting this on my end for the last two days...
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again.
** Locked files will also be deleted.
1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens.
2 Press the up or down arrows button to choose "FORMAT".
3 Press the REC/SET button again.
4 Press the FF or REW to choose "START".
5 Press the REC/SET button.
Formatting starts.
"FORMAT DONE" displays when formatting ends.
DS330 Memory error
You will need to format the memory. In the menu, scroll to format. All recordings will be erased.Tom
HOW DO I RESET DS-330
There is no factory reset but you can reformat the memory. Hold the menu button, scroll to format, press record and follow display instructions.
Device not detected
Try going into the BIOS (or CMOS) of your computer and look for
Legacy USB Enabled/Disabled
If it is set to Enabled, set it to Disabled
If it is set to Disabled, set it to Enabled
This sometimes fixes these kind of problems.
Hope this helps.
