20 Most Recent
Hitachi C12LCH 15 Amp 12Inch Compound Miter Saw with Laser and Miter Bevel Digital Display Questions & Answers
Where does the return spring attach to?
To reattach the return spring on your Hitachi C12LSH miter saw, follow these steps:
- Ensure that the miter saw is unplugged and turned off for safety.
- Locate the yellow protective cover on the miter saw. This cover is designed to shield the blade when the saw is not in use.
- Look for the small metal hook or attachment point on the yellow cover where the return spring should be connected.
- Inspect the return spring itself and identify the end that needs to be attached to the yellow cover.
- Align the end of the return spring with the attachment point on the yellow cover.
- Apply pressure and securely attach the end of the spring to the attachment point. It may require some force to hook the spring into place.
- Once the spring is properly attached, test the yellow cover by pulling it away from the blade. It should spring back into place when released.
If you are having difficulty locating the attachment point or need further assistance, consult the user manual for your Hitachi C12LSH miter saw. The manual should provide specific instructions and diagrams for reattaching the return spring. If you don't have the manual, you can usually find it on the manufacturer's website or by contacting Hitachi customer support.
7/2/2023 5:43:55 PM •
Hitachi Saws
Answered
on Jul 02, 2023
My Hitachi C10FS compound miter saw runs very unsteady. Power cuts in and out constantly. I just changed the switch and installed new brushes I
If your Hitachi C10FS compound miter saw is running unsteadily and the power cuts in and out constantly even after installing a new switch and brushes, there may be a few possible reasons for this issue:
Loose or damaged connections: Check all the electrical connections in the saw to ensure that they are properly connected and not damaged. Loose or damaged connections can cause intermittent power cuts.
Faulty power cord: The power cord could be damaged or have a loose connection, which can cause the power to cut in and out. Inspect the power cord carefully, and if necessary, replace it with a new one.
Faulty motor: If the motor is faulty or damaged, it can cause the power to cut in and out. You may need to have the motor repaired or replaced.
Electrical interference: If the saw is being used in an environment with high levels of electrical interference, this can cause the power to cut in and out. Try moving the saw to a different location to see if this resolves the issue.
If you have checked all of these potential issues and the problem persists, it may be best to take your saw to a professional for further diagnosis and repair.
3/22/2023 8:53:31 PM •
Hitachi Saws
Answered
on Mar 22, 2023
Hitachi chop saw c10fsb won't start?
Check the brush holders and make sure the brush can travel freely all the way down to the commutator.
Look down the brush tube with a light and turn the blade to rotate the armature - look for missing/burnt segments on the commutator.
Also, this has a soft-start module that can go bad - if the brushes and armature are good, switch rings out, and all connections are tight, I would lean toward the module.
6/14/2022 4:26:17 PM •
Hitachi Saws
Answered
on Jun 14, 2022
Re: Hitachi C12FDH single bevel compound miter saw. Bevel setting reads 0 degrees but it is not. I'm trying to install baseboards. Every bevel cut angles in from top to bottom about 1/8". How to fix?
Most saws of this type plus many others need checking and if necessary calibrating when delivered and from time-to-time during use.
There are usually adjustable stops and often moveable scales so when checked against known accurate squares and angles suitable adjustments can be made. Sometimes the stops aren't adjustable and metal must be removed by filing or added by bonding a suitable shim.
One point of concern with many saws of the type is the position of the handle is often offset from the centre line of the pivot with the result; the force needed to overcome the resistance of the return spring is also offset and tends to twist the mechanism during the cut - the typical mechanism is not usually strong enough or built with sufficient precision to completely resist the twisting force which often results in a less than accurate cut even though the angle has been accurately set.
Knowing this the user can compensate by holding the handle differently or applying a twisting force in the opposite direction. With practice you will become familiar with the tool...
10/8/2018 1:36:06 AM •
Hitachi Saws
Answered
on Oct 08, 2018
